Posts: 702 |
Alright Guys!!!!! This Is Being Made Way Too Complicated. If I Read This Thread Right, I Believe All You Have Done Is Broken One Of The Shift Cable Ends. I Will Go Back And ReRead This Thread Again. You Lost Forward Gears After You Launched Hard Correct?? Sorry I Just Read This Whole Thread In About 2 Minutes. I Would Pull Your Driver Wheel And Fender Liner And Check On The Shift Tower To See If One Of The Cable Ends Is Hanging Off. Does Your Shifter Assembly Feel Loose Inside The car When You Move The Shifter Forward And Back?? Let Me Know. I'll Check Back Tomorrow.
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 1,475 |
Did you ever study english in school? Shure looks like you didn't. Must Be Fun To Hold Shift Key Down Every Time You Type A Word.
Posts: 530 |
The shifter doesn't feel sloppy really.
What I think happened is that I broke an axle plan and simple, I will find out more tonight.
Terry suggests I send him the trans due to there being metal shavings from the broken axle.
What a great guy he is he even offered to go through the trans for free.
All I have to do is pay for shipping. The down times gonna hurt but what the hell. I only work seven days a week.
I'll let you know tonight.
Originally posted by MapOfTaziFoSho: Can u ask him to measure his shaft and compare it to your shaft?
Posts: 5,810 |
If it's just an axle, use a magnet and change the fluid! Screw pulling it out.
As far as procedure, I'd stick a telescoping magnet in where the axles go and fish around. Then when I drained the fluid I'd stick it in there too. Last, inspect the axle shaft first to see how clean of a break it was and how far into the splines it broke. It may be that it broke right at the edge of the splines where the oil seal rides. In that case, don't drain the fluid first, let the fluid push out the material through the axle holes when you finally pull the old axle out.
Heads up, youmany need to pull the passenger axle intermediate shaft to push out the piece of axle that is stuck in the shaft. IDK about the quaife but the torsen has a small hole in it that you could use a long punch to push the piece of axle out of the differential from the opposite side.
See My Mods
Posts: 4,051 |
Originally posted by akrump47: Did you ever study english in school? Shure looks like you didn't. Must Be Fun To Hold Shift Key Down Every Time You Type A Word.
Posts: 1,194 |
Originally posted by CSVT1214: Originally posted by akrump47: Did you ever study english in school? Shure looks like you didn't. Must Be Fun To Hold Shift Key Down Every Time You Type A Word.
Posts: 21,197 |
Originally posted by warmonger: If it's just an axle, use a magnet and change the fluid! Screw pulling it out.
.......shows that some owners would put an expensive diff unit at risk Vs doing the job correctly! It's half a**ed and the chances of leaving debris in the diff very high. If you fully understand the construction of an ATB diff you would know that it is very easy for debris from the shaft to make its way to the sun & planet gears and cause damage. If the diff(Quaife ) still failed after this poor attempt at removing the metal Quaife WOULD NOT honor any warranty as the fault had not be caused by their part. Bad post to encourage owners to risk such a high cost component...not very smart at all.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 5,810 |
Originally posted by todras: Originally posted by warmonger: If it's just an axle, use a magnet and change the fluid! Screw pulling it out.
And on the flip side, this mysterious voice from heaven popping in an telling people they do half-assed work is just another ploy to mindfukk people into thinking that he is the ONLY one who can do work on these cars.
 You may not charge him any more but it's like crack cocaine, get everyone sourcing through you so that you are the only dealer anyone thinks about. Maybe good business sense for you, but don't do it at my expense!
ANY person would be a fool to just yank a transmission without examing the damage, esp. when it is probably easily viewed from an exterior point. Period. If the axle sheared then there are probably little to no pieces anyway, probably just the two surfaces.
I guarantee you your precious Ford Dealer techs would NOT be told to pull the whole transmission and tear it open if an axle sheared. The Ford Reps wouldn't even pay the dealer for that labor unless they had a good reason for it. So don't try to take every opportunity to make me look bad that you can. You just make yourself look bad in the process. And don't talk to me about half-assed, I don't have things like Frankentrans under my belt nor do I have sometimes 8 month waits for me to produce work for another customer.
If this guy can't assess his transmission then he should pay to send it to you. If he can then he should do the examination and possibly follow my alternative...which is just all it is an alternative.
See My Mods
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
(snip)
All I will say is, and wheeeeeeee. Leaking Frankentrans reporting in!
Chris
NJ
98.5 SVT Silver Frost
Posts: 6,760 |
Originally posted by Shaggy: Originally posted by warmonger: (snip) And on the flip side, this mysterious voice from heaven popping in an telling people they do half-assed work is just another ploy to mindfukk people into thinking that he is the ONLY one who can do work on these cars.
(snip)
Ryan
Trollin!
