Posts: 1,859 |
Stock clutch and disc? Sounds like a broken clutch disc, or something along those lines.
The Focus towers don't break, Terry has only had one reported broken. The upgrade is just extra precaution.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 530 |
well here we go....
I bought car which just had tran replaced... (diff pin) I didn't know at the time of purchase
I blew diff pin. I installed a used trans (had no dough)
That trans broke, not the diff pin but the spider gears. Installed HMS trans ($1600) Just broke it tonight. But most likley just the shift tower.
I wasn't shifting when it broke just launching hard.
As far as you never breaking anything... you had a zetec, that even with a blower barely put out the #'s an SVT does if I'm not mistaken. You also had an ATX no hard launches there!! SO I thinking I appreciate your input sir but keep your crappy comments to your self.
I'd like to point out TWO things
1. I am getting harassed by a MOD!! 2. MIKEY BOY FOR MOD OF W. GREAT LAKES!!!
Learn how to drive NO Learn how to drive like a sensable person YES.
Originally posted by MapOfTaziFoSho: Can u ask him to measure his shaft and compare it to your shaft?
Posts: 530 |
Originally posted by livinsvt: Stock clutch and disc? Sounds like a broken clutch disc, or something along those lines.
stock clutch and disk...
yes....
Posts: 4,141 |
Originally posted by livinsvt: The Focus towers don't break, Terry has only had one reported broken.
If they don't break.....why has he reported a broken one???
Everything is breakable.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 530 |
Originally posted by ray: Semi-Social is the key.. you can disagree, but being personal is NOT going to be tolerated.
Hector you are not being Semi-Social
Posts: 1,361 |
I say just give Terry a call. He probably knows EXACTLY what happened. Probably could provide solutions as well.
'98 SVT Contour, in at least 639 pieces ![](/ubbthreads/images/graemlins/blackeye.gif)
4 Speed MTX...synchro and shift fork replacement in progress
Posts: 3,732 |
Originally posted by BlackBirdRacing: As far as you never breaking anything... you had a zetec, that even with a blower barely put out the #'s an SVT does if I'm not mistaken. You also had an ATX no hard launches there!!
i bet ya no matter what you do your car couldnt touch my car off the line when it was a 3L ATX. when the tranny was good and i had decent tires it would launch HARD (3500 stall does that) ive taken 5.0 5spd mustangs off the line and kept running away from them. now that i got a mtx....well i better learn how to drive this thing
Russell
Oval Port 3L Nearly Done
Posts: 3,816 |
What happens when you put it in gear and rev it?
...Or can you even put it in gear?
Reason I ask is because I stripped my halfshaft once and it lost all movement (with an LSD...). I would put it in gear w/o needing the clutch and revving would cause the speedometer to go up a bit like you were spinning the tires.
Posts: 530 |
sure a 3l yeah there's a great comparison.
let's see. who here has broken axles with there atx, and wasn't turning corners.
I'm sorry but if you don't have a stall converter, then you don't have the drivetrain "shock" of a hard launch that a manual tran has.
The factory controlled ATX also will not allow you to shift as fast as any person with an MTX.
Note the word FACTORY CONTROLLED.
CEG road warrior
CEG road warrior
Posts: 17,248 |
I beat the hell out of my car EVERYDAY until I got rid of it at 140k. The supposed weak CD4E took it like a champ. Did I mention it did this with 70 MORE WHP. ![](/ubbthreads/images/graemlins/nonono.gif)
I am no expert....but transmissions "just don't break" without any persuasion from the driver. That's just how it is.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
