Posts: 5,975 |
Originally posted by Tourige: Originally posted by GTO Pete: You can take it even further and dremel down the uneven "ridges" inside the TB. Knife edging is also an option.
Thats a little more extreme, its also prone to over dremeling and then you need a new TB
Knife edging can be. For the ridges, it's not "prone" to it. There is plenty "meat" there - unless you go absolutely crazy with the dremel. I've optimized ~6 TBs and never had a problem.
Posts: 2,978 |
Learned patience the hard way
Posts: 2,454 |
Originally posted by posthuman63t: Didn't buckshot used to offer these? I'm assuming not any more?
I still do offer it, just not as a core exchange service so you have to actually send me your TB and I'll optimize it right away and send it back.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 129 |
When I said "bore" I was referring to the process in general. I'm aware that it's a countersinking screw process. "Countersinking screw process?"
'98 CSVT Black
-AEM short-ram intake
-Optimized TB
-Optimized y-pipe
-Magnaflow cat-back
-B&M short-throw shifter
-UD pulleys
-Poly mount
"It's quicker than it was stock!"
Posts: 1,746 |
Originally posted by Buckshot77: Originally posted by posthuman63t: Didn't buckshot used to offer these? I'm assuming not any more?
Rick
Looks like I'm gonna have to find a spare TB then.
2000 Contour SVT
SF - #542 of 2150
Posts: 1,423 |
Originally posted by GTO Pete: Originally posted by Tourige: Originally posted by GTO Pete: You can take it even further and dremel down the uneven "ridges" inside the TB. Knife edging is also an option.
Dremeling down the edges to remove the ridges will work but will not give the best/cleanest results and can take a lot of time. I have done a few and along with modifying the TB shaft on a Milling machine (not by hand) I taper the intake side and the output side of the TB on a lathe to get a perfectly smooth finish and even transition from the 60mm bore to the outer edge. Also by doing the TB shaft in a mil you get precise accuracy and a perfect countersink on the TB plate. This is an example of what Pete is referring toâ?¦these are a SVT TB non-optimized and an optimized 65mm Mustang TB. Note the outer edge difference between the two (the TB shafts have not yet been done in this pic), the SVT edge is thick and the Mustang is very thin â??razor likeâ?. This eliminates any ridges from the intake tube into the TB creating smoother airflow.
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 46 |
i was thinkin about doin this to my TB but can someone write specific directions that i could follow.... thank you
98 black csvt
Posts: 1,616 |
Posts: 5,975 |
Read the Stickies.
Posts: 10,015 |
I optimise TB's too. If you want more info - PM me.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
