Hahahahaha, another CSVT owner that's hooked
How much power would you like to get out of your car? Is it mainly a daily driver that you rip through the streets/highway with?
The easiest and most bang for your buck setup would be to find a low mile '01 or newer 3L with the typical mods and upgrade to clevite77 rod and main bearings and swap in your SVT cams w/ their timing assemblies.
You can keep the 3L oval port UIM and LIM, but you would need to make a custom fuel rail.
-OR-
You can port match the 3L heads to your SVT UIM and LIM ( Along with porting and polishing them....)to make "tumble port" heads. This is the more envolved option, but you will get a lot more power by doing this. I went this route with my car(amoung other things)..... and turbocharged it for good messure
![](/ubbthreads/images/graemlins/laugh.gif)
As far as your trans goes, you can either have HMS rebuild yours with every upgrade available and an LSD ($1500 +/-)
-OR-
You can go through Exdelayed or
www.car-parts.com for a used Duratec MTX75. I'd look for a non-SVT trans as they are most likely less beat, and look for a 2000 or newer as they have the most currant upgrades. One can be had in the $400 range. Add a Torsen LSD for about $500, and you're good to go.
Hope that helps,
Daymon
