#1537749 03/29/06 11:45 PM
i have had a cel on and its p1518. wich is says the manifold secondaries are stuck open. i checked it out and its not. i have a new imrc and i had it mounted on the battery rack and it fell off. i think when it hit the tranny it must have did something to the box. ould something in the box be loose causing the cel. my secondaries seem to be working fine, and i remounted the box differently.
98 contour s.e. sport mtx http://www.cardomain.com/memberpage/503352 all mods shown on page
#1537750 03/30/06 01:14 AM
F
F
I dont have an answer to your question but you were my inspiration to relocate my IMRC...so now i betta double check that mine is nice and secure...i will say this tho...the electrical connector is pulled really tight on mine...if yours is the same..maybe a wire is not fully connected but not visibly separtated if that makes sense.
98 Silver Frost EO 90 Grand Am H.O. Quad 4 300,000+ miles
#1537751 03/30/06 02:15 AM
Originally posted by cvkillacontour98:
...i have a new imrc and i had it mounted on the battery rack and it fell off. i think when it hit the tranny it must have did something to the box. ould something in the box be loose causing the cel. my secondaries seem to be working fine, and i remounted the box differently.
In this thread which you were part of, beyondloaded mentioned the IMRC breaking when it was dropped 3 feet.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=perf&Number=749718&page=&view=&sb=5&o=&fpart=all&vc=1
#1537752 03/30/06 02:39 AM
mine is still mounted to the battery rack but with 4 zuip ties and they are real tight. a mechanic i was workign with at my last job zipped it for me when he changed out my clutch. with the 4 zip ties it stays out of the way. ill take a pic of it and put it on my car domain page to replace the old single bolt pic. i just hope i dont have to buy another imrc to make the engine light go away.
