#1537457 03/29/06 06:52 PM
it doesn't happen everytime but sometimes when I start my car up the coolant light stays on for like 5 or so min. until the engine warms up... I was told that it's prob. just air in the system, and needs to be purged out....
If this is so, how would I purge the air out and/or do I need to do a coolant flush??? I did flush the coolant in October and this problem only started like 2 or 3 weeks ago..
any help/suggestions you guys have is greatly appreciated.
Thanks
-Keith
Keith P. Killed in action-4/27/06 '99 CSVT #2369/2760-7/28/99 New Recruit- 1998 EO CSVT # soon to come Black 106,xxx
#1537458 03/29/06 06:55 PM
Add a pint of coolant. That should take care of it.
#1537459 03/29/06 07:06 PM
Overfill by 1/2"
See FAQs on MAIN SITE
Steve
#1537460 03/29/06 07:17 PM
If that doenst work its most likely the sensor like in my car. Its annoying but i dont mind it too much. Too poor and in college to get teh sensor... esp because ford makes you buy the entire coolant tub too.
Brett The man thinks its best for everyones safty if i dont drive for 6 months '95 Moonlight Blue Contour (ITS ALIVE AGAIN!) MODS: Knauberized,Reverse Indiglo Gauges,LED's,AEM Intake,Rust holes for more power!
#1537461 03/29/06 07:41 PM
Originally posted by projectSHO89:
Overfill by 1/2"
Steve
I'm pretty sure it has nothing to do with the level as it is just above the fill line now, and I have had it go below before, and when that happened the light stayed on.
#1537462 03/29/06 09:42 PM
Check for holes in the hoses. My upper radiator hose had a pin sized hole and it caused thee EXACT problem you just described.
#1537463 03/29/06 09:52 PM
Overfill by 1/2"
Steve
The sensor is faulty on the duratecs, the level needs to be above the full line before the sensor doesnt see that its low.
#1537464 03/29/06 10:07 PM
Usually once I get the car moving it jostles around the coolant and hits the sensor and it turns off.
98.5 T. Red Contour SVT Lowered on FSVT's http://www.cardomain.com/ride/2154233
#1537465 03/30/06 01:39 AM
Or the level goes up a little as the coolant heats up and expands.
#1537466 03/30/06 01:54 AM
Overfill by 1/2"
Steve
Faulty? I don't think so. It needs to be just at max or slightly below. If that doesn't work there is other problems.
