Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 8,445 |
Hair, poontang, or cherry?
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Highly Medicated Member
Posts: 2,882 |
Originally posted by todras: I like pie.
We care. Don't you have a meet to miss?
Semper Fi
"They've got us surrounded. Poor bastards." -Chesty
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
I Did that thing once At Norway Mountian in da UP eh....
When you hit the water at like 60mph its kinda easy to make it all the way accross
Posts: 21,197 |
Some of us are building Contours so more of them can be at future meets. Like the ones where ppl don't run into each other.
-'96 SE MTX 3L
Posts: 1,889 |
"If the water is very clean and is not agitated or disturbed it can cool well below the normal freezing point without freezing."
The water in the picture does appear to have been disturbed (again with the skiers and snowboarders) and does not look very clean (clean = free of contaminates). Therefore the water could be below 32F and still in a liquid state.
These two statements appear to be a contradiction.
My original smart azz comment was and is that I think the OP over or under(depending on how you look at it) estimate the water temperature. Even sea water(salt water) freezes at more then 10F(22F I think, it depending on the salt content) not to mention water that cold(if you could get it that cold without freezing) is deadly.
99 Contour Sport SE MTX
KKM filter, B&M shifter
No res, BAT kit
Green car silver hood (because silver is faster)
Posts: 4,220 |
First off I'd like to say that my initial comment was a blatant misreading of what was initially said. I read that the temperature outside was 10 degrees, and of course water can still be liquid when it's 10 degrees out and even much colder.
I understand exactly what RT is getting at. Pure water, technically, can't get colder than 32 degrees in its' liquid form. It turns into ice at that point. Even if its' highly unpure, the freezing point isn't altered that much.
But the real question here, and one that I honestly don't know the answer to and can't find an answer to, is what temperature water turns to ice provided its' being violently disturbed every couple of minutes. I've seen waterfalls freeze, so it's possible for rapid moving water to freeze, but there's a significant difference between moving water and a violent disruption of the water's surface by jumping in it.
Basically, what would happen if you put a bowl of water into your freezer and repeatedly dropped something heavy into it? Would the temperature of the water approach 0 degrees without freezing? Or, would the repeated violent motion of the water create enough molecular friction that the reason it doesn't freeze is because it doesn't actually get that cold?
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
