Posts: 41 |
I have noticed that my 98 Contour has moisture in the trunk. Mostly after washing and heavy rain. Can I get some advice on the normal places that these trunks develop leaking issues. And of course any help in determining where the leaks are would be great.
-sp
Posts: 3,570 |
I had rust develop around the bottom of my rear window and created way for water to get into the trunk. Had a shop remove the window, clean it up, and repaint to fix. Thats just my experience, I'm sure there are more common places for leakage though.
Posts: 9,872 |
Originally posted by rkneeshaw3.0: I had rust develop around the bottom of my rear window and created way for water to get into the trunk. Had a shop remove the window, clean it up, and repaint to fix. Thats just my experience, I'm sure there are more common places for leakage though.
why whole trunk carpet got messed up due to moisture from my rear reflector not being sealed properly
Posts: 41 |
Is there a fix for the reflector issue?
-sp
Posts: 663 |
get in there with a flashlight, close the trunk and have someone run a hose over it for a little while. Locate the leak and fix it...........
Keith P.
Killed in action-4/27/06
'99 CSVT
#2369/2760-7/28/99
New Recruit-
1998 EO CSVT
# soon to come
Black 106,xxx
Posts: 735 |
I've noticed that when it rains (or has rained and the car is wet)and you open the trunk, water drips in from the bottom corners of the trunk lid (or what was the bottom corners when it was closed). That causes moisture in mine. I just hold it open a bit to let the water run off, then open it all the way. Still get some drips though....
'99 Sport TropicGreen,Duratec, SVT exhaust, Brembo rotors, Ceramic pads, K&N filters(oil & air), Alpine CDM7874, Polk DB570 speakers front and rear. Fog light mod. 50% Formula One tint.
Posts: 13 |
Two leak locations that have soaked my trunk over the years were: 1) Air exhaust vents. These are plastic inserts (mine had cracked) hidden behind the fender side trunk liners on each side. They snap in from the outside which means (at least on my SVT) that the rear bumper cover had to be removed to install the new vent.
2) Small leaves, maple seeds, misc. dirt builds up behind the tail light pods so that water drains into trunk instead instead of around the light and out. Easy fix. Pop out the module, clean, and you're back in business,
silver '98 E0
bone stock except
225/60 -16's on 16 x 7's (45 et)
