Posts: 18 |
OK so I have 2 issues.
1. (Minor Issue) I got my car back from the mechanic missing a center cap for one of my wheels. Of course he insists it was on the car. Whatever... Does anyone have an extra E0 SVT center cap they would like to sell?
2. (Major issue) I lost my burst at 4,000. I think I have had this issus before, but it was covered under warranty. Not so anymore... I know sometimes on long beatings it would go out and I would just turn the ignition off and back on and it would be fine. This hadn't happened in a long time and then on the way back to the city one day it just went away. Any suggestions? Disconnect battery to clear memory maybe? Please help, I am dying, the car is so damn slow.
Thanks, Chris
Posts: 9,442 |
Secondaries arent opening, most likely the IMRC box located under the plastic cover on the front of the engine.
Removing that cover and leaving it off sometimes helps abit....
Posts: 9,065 |
Originally posted by Bk4293L: Secondaries arent opening, most likely the IMRC box located under the plastic cover on the front of the engine.
or a plastic grommett broke...
Posts: 18 |
plastic grommet? i am a retard when it comes to this stuff. ford has replaced the IMRC once before on this car, but that was more than 10,000 miles ago. is there any way around replacing the IMRC?
thanks for the help guys. oh and they found my center cap under the tire machine... how random.
let me know
Posts: 10 |
First I would make sure your IMRC is still properly connected to the secondaries. Next, try letting it sit over night to cool off and see it they will work when the engine is still cold. If the secondaries are still not opening, you need a new IMRC my friend.
You could try manually holding the secondaries open with some form of a wire tie back or something (sorry, haven't had to investigate this linkage). I would have to believe your car would be a little sluggish down low and may end up killing your fuel economy below 3700rpm. The A/F ratio would lean out with the additional air flow below the normal secondary opening point and the EEC would begin dumping fuel to make up for the lean condition. Just something to keep in mind. Good luck.
98 E1 SVT Contour - Original Owner <-- $5500 obo.
86 SVO Mustang
Posts: 728 |
I have a spare IMRC if you need to buy another.
Crispy
99 Cougar - Arancio Atlas/Grey Graphite Pearl Custom Widebody
98 CSVT - Silver Frost #4014/6535 - Born 10/21/97
98 CSVT - Silver Frost #4085/6535 - Born 11/10/97
See My Rides
Posts: 18 |
I am going to try messing around with it today. I am pretty sure it is shot. Thanks for the help and I a sure I will end up contacting NV to scoop up that extra IMRC of her's ![](/ubbthreads/images/graemlins/smile.gif) Thanks again, I'll let you know what happens. Chris
Posts: 21,197 |
Originally posted by cpapsSVT: plastic grommet? i am a retard when it comes to this stuff. ford has replaced the IMRC once before on this car, but that was more than 10,000 miles ago. is there any way around replacing the IMRC?
let me know
Ford parts have a 12k warranty.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
