Page 4 of 6 1 2 3 4 5 6
#1533163 03/23/06 07:46 PM
Good to hear. Lets see the pics of the final install.
#1533164 03/23/06 07:47 PM
Originally posted by Tourige:
Originally posted by RawBurt:
Originally posted by starjammir:
Probably wouldnt be good for me then...I dont do a lot of agressive driving.
Bill, did you forget when we tested it out in your car? It is definetely noticable in everyday driving.
just in body roll or what?
turn in
ahh
I want to reduce my body roll, but i cant justify spending another 300 bucks on a Front and rear tower brace.
body roll is related to the sway bars
#1533165 03/23/06 07:59 PM
You beat me too it.
I can't believe how many people confuse the functionof a Strut Brace with Sway Bars.
#1533166 03/23/06 08:05 PM
still need to clean up the carpet but this is where its pretty much staying.
98 CSVT t-red 1737# cf1 Cowl hood Centerline Storms CEG Dragon Run- Oct 13-15 WTB- Vortech S/C kit/ADC Turbo Kit
#1533167 03/23/06 08:21 PM
Much better john
Am I the only one who mounts it with the nut on the driver side of the trunk?
Mounted strictly for picture purpose.
#1533168 03/23/06 08:27 PM
Shoot dude, what did you use to cut the carpet?
Using a utility knife (with a sharp blade!) you can make some slits in the carpet going back to the closest edge and slide the bar in. Better yet, pull the carpet back, install the bar and tighten it up, then start to get the carpet settled around the bar. You can make out where I cut my carpet in this pic:
I first installed the bar, then made the cut in the carpet to fit it around the bar.
Another nice benefit of this method is that the cut, although it doesnt show up much as it is, is hidden from the view of the open trunk by the bar itself.
To others who do this and use the method described here, just take a little extra time and cut an inch at a time in from the edge until the carpet starts to sit nice and flush again. That way you ensure you're cutting the slit in the right direction towards the point the bar protrudes through the carpet.
#1533169 03/23/06 08:50 PM
i used a utility knife also. i messed up big time i kno lol
#1533170 03/23/06 09:09 PM
Just got mine today . Installed with in minutes with nut on driver side.
RVM Short Shifter RVM Intake Pipe Full Kenwood System NX Neons "If you can read this, thank a teacher; If you are reading this in english, thank a soldier"
#1533171 03/23/06 09:54 PM
Are you guys lefties?
#1533172 03/24/06 12:58 AM
righty
