Posts: 432 |
I just wanted to see when the redline meets were to start again because i have a new project car im working on and am trying to get it ready before the meets start up again , Its a 79 Camaro with a 455 buick supercharged , the camaro has a 12 bolt chevy in the rear 5.13 gears , nice little 1/8th mile car with the gears i have now, i also have a set of 4.10 for the strip.
Posts: 6,791 |
Sounds sexy!  The meets will start up weather permitting. Check out there website
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,106 |
Originally posted by SvtEdwardo420: Its a 79 Camaro
Originally posted by Rawburt: Sounds sexy!
These two quotes are not to be used in conjunction with eachother.
Mark
2000 Black CSVT
Posts: 21,197 |
-'96 SE MTX 3L
Posts: 1,695 |
Why a Buick engine? just to be different?
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift"
"They have diarrhea of the mouth, and constipation of thought"
Posts: 6,791 |
Mark
You are right, the front end does look terrible, but still...
I feel Guilty, Oh so guilty
Posts: 4,789 |
Unfortunately, having a seperate set of gears for the strip doesnt work well. Ford 9" rear-end are a piece of cake. A 12 bolt is an absolute [censored] to swap out gears.
-Mitch Hedberg
Posts: 432 |
yea its not the funniest thing ive ever done, but the 455 i already have in my drag boat and the hull is shot, so im scraping the hull and rebuild the motor for the street because right now its cammed for the water . but i have unlimited dyno time here down at school so ill be able to fine tune it. along with unlimited machine shop so i cant wait. i have a little 350 in it now , but im not going to release it until i get it complete, atleast until i put the big block in
Posts: 9,196 |
Originally posted by ChuckNorris: Why a Buick engine? just to be different?
Let me show my "automotive ignorance" here The Buick motor is a torque monster and if its a 70' GS455, its puttin' down 510 ft/lbs of torque @2800 rpm and thats in stock trim! Horsepower is "rated" @ 370. Adding a set of headers, aluminum intake, better carb thats re-jetted and messing with the timing, should net pretty good results. Now if you get into a set of aluminum heads and bump up the compression ratio, not to mention a good roller cam, look out
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
