Hi. Before I test the wires going to the fuel pump, wherever they are, I want to check the fuses. The problem is I bought my 1997 Contour used. It ran enough to drive it home, but has sat for several months. Apparently I need the owner's manual, which is gone, or a Chilton's, the Haynes I have does show the fuses IDs. So since everything is closed, does anyone know where a diagram of the fuse panel exists on the web or which interior fuse is for the fuel pump. I checked all of the fuses in the engine compartment and they were good. My Contour has a 4 cylinder engine. Any help would be appreciated.
Thanks.
