Posts: 9,065 |
hack away... it got in the way of progress...
Posts: 352 |
I will.  Originally posted by todras: Who is going to know? The seat covers it up.
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 5,810 |
Originally posted by todras: What's with the Cougar guys dropping the tank? Dan G then you. Crazy crackers.
Hahaha, No Shyte!! LMAO
See My Mods
Posts: 5,810 |
Originally posted by DanG: I told you guys this before- Cougar's access ports in the rear floorboards are too small to fit the pump housing through! You'd have to cut the floor, then find some boondoggle to re-seal the thing. No thanks. The tank drop is easy enough.
And I responded to your post on NECO, Instigator- You pushed the fill-neck seal into the tank- No seal = lots of fuel on the ground!
So are the contours.
Can't cut some sheetmetal?? Hardly. One look at the amount of work to drop the tank versus two 2" cuts that allowed me to bend the metal up enough to R&R the pump....I was sold. Took all of two seconds to decide that mental battle.  Especially when it is covered by the seat, can be bent back into place, and sealed with RTV along with the stock rubber plug put back into it. No leaks, no corrosion, no excess work, no issues with structural integrity........ ...having the time to go blow more money on my Visa Card....priceless.
See My Mods
Posts: 21,197 |
Also don't have have to burn up the gas in the tank so it won't weigh a sh*t ton? More $ out of pocket. Also if you have a FP issue you just need to pop the seat and pull back the metal. All of 5 minutes. It's a Contour/Cougar. It isn't worth anything to anyone but you. Having a couple cuts for access to a FP is the last thing I'd think about.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 68 |
if i happen to solder those things and my chip still not work.....will the ecu still function properly while i have the chip removed?
Cougar is no more, parts for sale.
Built escape 3.0 w/ 8.5:1 pistons, PnP heads, ovalport/mazda6 cams, SVT manifolds, the works
entire car for sale PM me if you want a part!!!
Posts: 68 |
anyone know if the ECU will work after the soldering is done and no chip is installed?
Posts: 10,015 |
Yes it will. It is purely to allow a chip to works with PATS.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
