Posts: 951 |
Is there anything wrong with using a different amplifier on each voice coil of a subwoofer? For example, if I had a 4 hom DVC sub, and I had two identical amplifiers, if I bridged each amp and used them on different speaker terminals on the subwoofer, made sure that the gains/xover/bass boost/etc on each amp were at the same level, would that cause any harm to the subwoofer?
...the reason I asked is because I just got my hands on a RF Punch 400a4 (old school) and I wanted to use it with a Kicker S10L7. The amplifier is powered at 200wrmsx2 if you bridge channels 1+2/3+4
Thanks for your help
1999 SE White
AVH-P6500DVD
Infinity Reference 6500CS
Pioneer 5x7s
Punch 360a2
Punch 500a2
Adire Tempest in a custom sealed 3.4cuft box
Modded Xbox
Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
Posts: 252 |
that you can do safely with a 4 channel but as far as 2 seperate amps you never find 2 amps that actually put out the same power even with gain levels and such. You would have to level match them with a volt meter
I feel Guilty, Oh so guilty
Posts: 4,789 |
why would you have to level match with a volt meter?
hint: i'm setting you up.
-Mitch Hedberg
Posts: 7,392 |
Originally posted by dnewma04: why would you have to level match with a volt meter?
aren't you supposed to be in FL?
02 Mustang GT... Tuned by Nelsons. Low 12's, anyone? ![](/ubbthreads/images/graemlins/smile.gif)
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
Posts: 951 |
Originally posted by icysvt: that you can do safely with a 4 channel
does everyone agree? also, i dont know why i gave you guys the 2 amplifier scenario, cause im using a 4 channel amplifier. i think that example came from the memphis website, where they were talking about a quad 1 ohm subwoofer, and customers putting 4 amps on that one subwoofer
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 4,789 |
there is no problem with running seperate channels, seperate amps, etc.
-Mitch Hedberg
Posts: 127 |
It is "possible" to wire it this way. But it is the least effecive and most costly solution.
You would need to RCA Ys. take the Subwoofer preout and Y the SUB rca into all 4 inputs of the amp so they all get the same exact signal.
Then you would need to gain match each channel with a multimeter.
Failure to properly match each channel will result in poor performance from the subwoofer and possible damage.
Both channels MUST be 100% the same. If one is off just a little each voice coil will be putting out a different signal and they will fight each other reducing your volume, greatly increasing distortion and heat. Which could damage your amp and your sub.
So my answer is NO. Dont use that amp for your sub. More trouble than its worth. Use that amp for your mids/highs and get a mono class D subwoofer amplifer with at least 400-600 watts RMS x 1 @ 2ohms.
Cougar V6 MTX: GMK Carbon Fiber Cold Air Intake : SVT UIM : SVT LIM : SVT TB : MSDS Headers & Ypipe : TruBendz 2.5" Borla Single Exhaust : Soild Front Motor Mount : & more
Posts: 127 |
A 4ch amplier is essentiall two 2 channel amps in a single housing. Each pair of channels has it own indivuals gain settins.
Additionally amplifers which are capable of being Strapped together would use a special cable in order to automatically gain match multiple amps to one another.
Kicker subwoofer amplifers for example have this abilty. one amp becomes the master and the other amp is the slave.
This allows you to take 2 amps and put out double the power at double the oms.
example. The kicker kx400.1 is 400watts rms @ 2ohm. If you strap two together you get 800watts rms @ 4ohm. That quad 4ohm sub could then be wired to two kicker amps. 2 voice coils per amp.
Posts: 4,789 |
Originally posted by GrandMasterKhan: Failure to properly match each channel will result in poor performance from the subwoofer and possible damage.
Wrong, wrong, wrong, and one more wrong for good measure. The original development of DVC drivers was to be able to produce both sides of a stereo signal with one driver. Providing the VCs are not playing the same signal but with reverse polarity, their will be no damage caused by playing signals that aren't exactly the same.
-Mitch Hedberg
Posts: 127 |
Your going to say that at high volume if channel 1/2 is set to +3db and channel 3/4 is set to 3.5db then it wont cause any harm or distortion?
The whole point is for harmony. If the voice coils are not getting the same signal it is like two people siging slightly out of sync. Sure it might not cause the amp to blow up or the sub to blow. But its not ideal and *might* cause damage over time vs a properly setup single channel setup.
Needless to say find a single channel monoblock amplifer and avoid all the multichannel BS. Its not worth the trouble.
