Page 2 of 3 1 2 3
#1530345 03/21/06 01:20 PM
....now how can anyone answer that?...Do you know what
you are looking for when you open it up?...Do you know
how to assess wear on components in an MTX?......and
would you know for example how to fix say a 3rd or 4th
gear worn blocker ring if you found it?....Think about
it!!!!
#1530346 03/24/06 03:27 AM
lubas79 Offline OP
so you're telling me I have to go to the mechanic to make it happened hmmmmm I know I can do it
1999 CSVT
#1530347 03/24/06 03:43 AM
i installed my own torsen and im about to install my own zetec FD ratio and upgraded shift forks. how-to will be made for the zetec fd ratio
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#1530348 03/24/06 01:10 PM
I hope you post TWO how to's. One for each type of output shaft and pinion assembly. One with two piece or 3 piece output shaft and with part numbers.
#1530349 03/29/06 04:45 AM
Originally posted by todras:
From Terry...
*No set up of new Quaife/Torsen diff bearings resulting in diff flopping around in the gear case like a d**k in a bucket!
*No sealer or incorrect sealer used on TOB fitting resulting in trans fluid leak into bellhousing*'Shaft' swapping from one trans to another without renewing bearings or setting up pre-loads
I'm kinna curious here...
I remember a lot of jive about not needing to shim a new diff. I still wanted to do it "by the book" so I checked the preload but prior to that I tried to order the shims just in case. Preload was well within spec despite my new Torsen and bearings. They do not exsist from Ford. Anything you order from Ford comes from MicroCad (the program they use to order parts). It does not exsist on the exploded view nor does it exsist in the service manual.
TOB
In the Ford service manual it claims NSR. I didn't use any sealer and I have no leaks.
The ONLY 96 (engine) 3L Build 'em fast. Spray 'em faster. ricehatersclub.com
#1530350 03/29/06 01:45 PM
BUNK!...to check the pre-load you need the 1.10 MM reference shim from the shim pack...I doubt the pre-load has been checked 'by the book'. In the clutch section it says 'apply sealer' to the new TOB before fitting. Ask Biggers what happens when you don't apply the (correct) Permatex to the TOB.
#1530351 03/29/06 03:34 PM
Why would you call me a liar? I most certianly did do it by the book. The special tool used to check for preload is actually an old Rotunda valve spring compressor. As for the shim there was one in there from the factory. And in the 2000 workshop manual it does not say to apply sealer to the TOB.
#1530352 03/29/06 04:52 PM
because you state you did not get a Ford shim pack. The shim pack contains the reference 1.10 MM shim. This is placed in the trans first, the end float/slack is measured with a dial gage, then you do the math per the book to establish the correct thickness shim to get the correct pre-load. Without building it up with a 1.10 MM shim you have no measurement. So how can the pre-load be correct?!
#1530353 03/29/06 05:18 PM
And I did measure the float or lack there of with a dial indicator. What do you think Ford uses the valve spring compressor for.
/thread
#1530354 03/29/06 05:38 PM
Page 2 of 3 1 2 3
