Posts: 5 |
I've been trolling around the forums for a while and found a lot of helpful info but I could use a few oppinions on this problem:
Car was running great until I changed the spark plugs, afterwards the car either runs really rough (at least one cylinder not firing) or won't start at all. I've since replaced all the plugs with another new set and changed the wires but I'm still having the same problem. Any ideas would be greatly appreciated!
Posts: 498 |
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 5 |
Yeah unfortunately that's the first thing I checked
Posts: 21,653 |
You do have the firing order correct (wires on the right plugs), right?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 498 |
Originally posted by SVTfrog: You do have the firing order correct (wires on the right plugs), right?
that was my next suggetion.
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
CEG road warrior
CEG road warrior
Posts: 17,248 |
Check the firing order. Sounds like you got some wires in the wrong spot.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 979 |
I hope this doesn't happen to me one my ignition wires arrive and the spark plug change. I'm going to take a pic before I do anything, so I don't mess up.
My ride(Cardomain link) :
'95 Contour 16V Zetec DOHC, Teal , ATX
Born on Sep. 4, 1995
86+ miles
*LEDs mods are on their way!*
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kerry2Kool4U: I hope this doesn't happen to me one my ignition wires arrive and the spark plug change. I'm going to take a pic before I do anything, so I don't mess up.
Do what I did.....mark the wires with a perm marker when doing a spark plug change. Remember 1 is the closest to the serpentine belt.
When changing the wires themselves.....do one wire at the time....that takes away that factor of messing up the order when reinstalling.
Hector
257HP/259TQ
160HP/141TQ
Posts: 5 |
Thanks for the suggestions, I ran the wires again and its still doing it. Mechanic says it probably 'jumped timing' , is this very likely?
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SignalD: Thanks for the suggestions, I ran the wires again and its still doing it. Mechanic says it probably 'jumped timing' , is this very likely?
It is possible.....but if started after the spark plug change.
Hector
257HP/259TQ
160HP/141TQ
