Posts: 21,197 |
If they are serious at becoming a supplier for the lube they should touch base with the Ford buyer who covers lube.FWIW this will NOT tell them the chemistry of the lube only the specs it has to meet Re wear rates on blockers,number of shifts,test rig set up,duty cycles of gears,bearings etc...The operational and conditions that the lube must meet....not what goes into it.THAT is up to the potential supplier to formulate to meet or exceed the testing.(FWIW,I have my own copies of the spec and background info,NOT for public debate/release)My 'brother ' engineers and I ,on a worldwide basis,are very tight with our info.Sorry,welcome to the 'darkside'.....have to be a 'member'!!!!
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,693 |
So then does this come down to the old concern about "Licensed by (fill in the automaker)" (such as in Mercon, Dexron, ATF+4), or "recommended for use where (Mercon, Dexron, ATF+4) is specified by (fill in the automaker), by (fill in the name of the lube supplier)?
For example, Chrysler did not until recently release the specs or make available the licenseing of ATF+4. Mobil specifies on their packaging that their Mercon V "is recommended by Mobil for use in Chrysler products where ATF+4 is specified" or words to that effect.
We had a similar thing with engine oil after the huricanes in the gulf coast where many oil refineries were temperarly shut down. Because of the shortage of critical ingredients the oil that some blenders supplied for a few weeks did not meet API or ISLAC specs and their labeling said something like "recommended for use where API SM is specified". Basically they used alternative blends that they did not have time to certify due to the emergency nature of the problem. Suposidly the alternative blends were "equilivant or better".
Even Ford with the Ford Honey somewhat did that on their literature saying that something like it was "appropriate for use where GL4 manual transmission fluid is specified".
When Ford decided to promote 5W20 engine oil, they proactively sought out Wal Mart to retail their 5W20 oil. As was explained on a national broadcast to dealer employees that it was done so that Ford could not be accused of requiring an oil that only they could supply.
Why have they not done something similar with Ford Honey? Did they feel that the likelyhood of a lawsuit or bad publicity was so small for this fluid for manual transmissions for Contour and Focus models only that no one would notice. Did they notice that Chrysler was getting away with the same thing on ATF+4 as well as Volvo, Toyota, and others that have hard to find transmission fluids?
It is outragous that Ford specifies an engine oil is a special labeled bottle for their transmission and commands $20.00 a quart for it.
I would wrlite more, but I have a plane to catch.
Luckily, there are blenders that are willing to provide a product that is "recommended" for our cars. Now we need to ferrett out which ones of the alternatives are the best. We know that Red Line MTL isn't one of them.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 314 |
Big Jim-
I appreciate your candor and I think you are on the right track.
I have tried: factory fill, Ford Honey, Redline MTL, ATF+3 (on your suggestion) and Royal Purple Synchromax. See my thread just below this one "... observations" for full details, but in summary:
I feel the best fluid, regardless of price, is the Synchromax. Considering price, the ATF+3 was almost as good as the Synchromax till it broke down with use. I am curious how the ATF+4 will compare to the older ARF+3. If the Synchromax is robust and outlasts ATF+3 (as it should) then I'll stick to it. If shift feel drops substantially in a couple years I may go back.
Brian 99 SVT
Posts: 5,810 |
Brian 99 SVT
Glad you like the Royal Purple, but you haven't tried Torco RTF yet....then again I haven't tried the synchromax either.
Still, the fully synthetic RTF has been the best all around shifting fluid I put in so far. I really really was impressed with how it performed cold and hot, there was no difference between cold (25-45F) shifts and hot (75-85F) shifts when I had my car.
You'll all have to wait for Ray to come online again and do a long term report on it though. I fully specified I had no idea how good it would be over the long run on both shift feel, protection, and and wear. I have a feeling it will turn out to be real good though.
See My Mods
