[size=18]
Rear Foot Well Lights all Model Mondeos [/size]
Just done this cool and very cheep Mod on my own car and thought i would share how i did it
you will need
A pair of bulb holders (i've used foot well lights from a mk5 Escort Ghia)
some wire
a bit of 1mm Sheet Metal
some Screws or Rivets
these are the lights i've used
first thing i did was cut some squares out of the sheet metal then cut a tab out of them to fit the lights into
like this
i then unbolted the front seats (tho it can be done without removing them)
and drilled 2 holes in the back part of the seat and 2 matching holes in the Brackets then i used Pop rivets (you can use self tapping screws) to secure the lights to the base of the Seat
Like this
i then conected the wiring and Routed it through to the front of the car
Wiring Diagram
[image]http://www.mondeosport.com/gallery/album87/Footwell_lights[/image]
bolted the seats back in and tested
hear is the finished thing
