Posts: 686 |
Originally posted by KingpinSVT: Well with the MSDS you could specifiy 2 or 3 bolt flange. If you got the 3 bolt, you have to get a flex pipe.
WHY GOD, WHY?!
LOL, ok... Well, I know why, I bought it used off another member. I'll prolly just save the headache/heartache and just get one of the 3-bolt cats from Trubendz... we'll see. The weird thing is, it doesn't look short. Like, it looks like it would mount RIGHT where my stocker does, but I just checked, and the flange is wrong. Ye-argh.
'98 Contour SVT - Please pardon our dust, under heavy construction.
'96 Escort LX - Pretender to the throne.
Posts: 36 |
This post has cleared up most of the confusion i had about parts needed for installing my weapon-r headers. So let me get this straight i will need the following parts for the install on my 2000 svt.
2 mil�s 1 flex pipe 1 test pipe from trubendz. Will the test pipe go where my CAT currently is? 1 3-bolt flange What other odds and ends would you suggest?
Blk 2000 CSVT
Posts: 343 |
you need MIL's.... you also need the flex pipe. You dont need a new test pipe. What you can do is remove the 2 bolt flange on your existing cat and weld on the new 3 bolt so that will connect to the flex pipe and so on...
DO you have the WR headers, becasue I have everything needed and I am sellign them
Posts: 3,637 |
Originally posted by ContourSVT93: you need MIL's.... you also need the flex pipe. You dont need a new test pipe. What you can do is remove the 2 bolt flange on your existing cat and weld on the new 3 bolt so that will connect to the flex pipe and so on...
I know i said that modifying the stock main cat is a good idea, but im starting to have my doubts as its kinda a PITA and your probably better off buying a hi-flow cat or a test pipe from trubendz.
Just my .02
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 343 |
A PINA enough to shell out the money?
Posts: 36 |
I have the wr headers and y-pipe. I am going to pay the $165 dollars and get this from trubendz. This is what your talking about when you said get the high flow cat...right?
Blk 2000 CSVT
Posts: 343 |
I beleive so. It has the 2 bolt for your existing side and then the 3 bolt for your new y pipe. You have a flex pipe right?
Posts: 3,637 |
Originally posted by ContourSVT93: A PINA enough to shell out the money?
granted you have someone who can weld for free and has access to a welder, it is cheaper, if your paying a shop to do it however, its probably cheaper and easier to just buy from trubendz.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 3,637 |
Originally posted by NorthPole SVT: I have the wr headers and y-pipe. I am going to pay the $165 dollars and get this from trubendz. This is what your talking about when you said get the high flow cat...right?
Thats the correct hi flow cat.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 3,788 |
That's the test pipe w/high flow cat that I got. The only issue I had with Trubendz, besides it took them forever to send it, was that they put an O2 bung on the test pipe. I told them TWICE that I did not need one but they put one in anyway.  Right now I have an oil drain plug in that hole.
