Posts: 6,910 |
I don't think I have seen it covered in any of the threads that I have read but is any of the hardware used to secure the header to the head one time use only or can the hardware be reused?
I plan to check the studs/nuts out before taking it apart so that I have enough new parts on hand to replace as needed
- 95 Mystique LS - Zetec/5spd
Posts: 6,791 |
I reused the all the hardware.
Posts: 7,117 |
NorthPole SVT... I strongly suggest you look under your car to see if you have the two bolt or three bolt flange. If you have the 3 bolt, you won't need the adapter parts except the fitting for the EGR. You can run the stock cat and get MIL eliminators & live happily ever after.
Posts: 3,637 |
Originally posted by BrApple: I don't think I have seen it covered in any of the threads that I have read but is any of the hardware used to secure the header to the head one time use only or can the hardware be reused?
You can reuse everything, i even reused the gaskets and i dont have any exhaust leaks. You can reuse the studs and nuts easily, but if your scared just buy new gaskets, its not a necessity tho.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 5,882 |
geez, had i known trubendz sold 3 bolt flanges i could have save myself $130! then again, its illegal in CA for a shop to tamper with a stock cat, at all......but i do know backyard welders..
Matt, i still have my stock 2 bolt flange cat if youre interested. all youll need then is the donut gaskets for your msds. do you have the msds Y pipe? or just going to optimize your stocker?
Posts: 9,872 |
I bought new studs and nuts because I knew living in New England, the sand/salt from the winters had mine all corroded and having my car almost 10 years old and as a daily driver, it was the best thing to do just to be safe..now I have heard many didnt need it, but imo its not a bad investment to have
Posts: 36 |
tour de force i checked i have the 3 bolt setup. So i need to get the flex pipe but i dont need the test pipe right? What is the EGR? thanks for the help
Blk 2000 CSVT
Posts: 343 |
Youll need the flex pipe. You wont need a test pipe unless your changing your cat.. if thats the pipe your talking about.
If your cat is 3 bolt the flex pipe and WR headers will bolt right to it....
Posts: 3,637 |
Originally posted by ContourSVT93: Youll need the flex pipe. You wont need a test pipe unless your changing your cat.. if thats the pipe your talking about.
wrong, if you have a 3 bolt flange then you have a stock flex pipe, the headers and y pipe are a direct swap.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 5,345 |
Originally posted by NorthPole SVT: ... What is the EGR? thanks for the help
He means the EGR tube (exhaust gas recirculation tube) which goes from the stock exhaust manifold (near the Bank 1 Upper O2 sensor) back to the EGR.
In this picture, it is on the right and it is covered by a "cloth" (?) heat shield.
Originally posted by chongo: Did someone call me out.......LOL
here you go.
Autozone has a good schematic and they call it Orifice Tube Assemby in Fig. 1.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/ca/1e/0900823d801bca1e.jsp
1996 V6 ATX 96K miles
