Posts: 20 |
Alright, I recently put up the post "New Member: What should I do?". Well, my dad, bein the kind of guy he is, tried finding me a better motor that will 'do just fine for now' since 'I dont need any more power'. Well he found a zetec out of a 99 mystique with 69,000 mi for 750 bucks that runs just fine.. not too bad of a deal, but the guy at the place doesnt know for sure if it will hook up. My dad also asked him about the zetec out of my 95 and says it will not hook up in my 97 due to difference in the sensors. What should I do now?! If it'll work I think I may just go with the motor out of the 99 and put my savings into more stereo, maybe suspension cuz I'm pretty sure it needs some new things here and there, rims, paintjob, etc. Any help from you experts out there?
'97 Contour GL MTX Blue
Stereo: Pioneer Headunit, Pioneer 6x8 3-way all around, MTX 421d Mono Amp, 2 10" MTX Thunder 5500's, Custom Split Box, 1.5 farad capacitor
Posts: 21,653 |
You'd need the computer and wiring harness.
But get a 96 or 97. OBD2 without that vct junk
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 5,143 |
yeah if you are going to replace the zetec in your 97 get a 96 or a 97 motor. 98+ Zetecs are different, and they have that junky VCT technology.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 498 |
vct is just more of a problem causer, look how many posts there are about CELs being 'timing off' or w/e.
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
CEG road warrior
CEG road warrior
Posts: 17,248 |
VCT sucks....nuff said.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 20 |
What makes the VCT a VCT?? I mean I thought itd be a good deal since itd save me some money but I didnt think it would have a better chance at bolting up anyways.. and how could I get the zetec out of the 95 to fit in my 97? According to what the guy told me dad, sensors, injectors, etc, all that electrical is different
Posts: 498 |
variable cam timing on the exhaust cam
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 1,687 |
And a not-so-cool valve cover, and a different oil filter and location, and a different intake, and a different sound....
J.T.
2002 Chevrolet Silverado 294ci V8. Custom CAI, headers on the way...
1997 Mercury Mystique Zetec ATX
Deceased February 2006
Posts: 1,085 |
Originally posted by Ed6407: What makes the VCT a VCT?? I mean I thought itd be a good deal since itd save me some money but I didnt think it would have a better chance at bolting up anyways.. and how could I get the zetec out of the 95 to fit in my 97? According to what the guy told me dad, sensors, injectors, etc, all that electrical is different
'95 = OBO I (Emmision Controls) '97/99 = OBO II
'95 = Return fuel system (fuel tank to injectors back to fuel tank) '97/99 = Non-return fuel system Forget the '95. It may be posible to sensor swap the '99 with the '97 sensors. Someone jump in here, what do you guys think?
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 367 |
Nope, the 99 would have VCT and that screws the whole swap up. What you really need to buy is a year-to-year match for your car if you want a complete engine. That is one with everything from the intake. head, block, and sometimes soem accessories like the alt. or power steering pump.
On the other hand, you could just buy a long block (that is the block with the head attached) from a year to year match or a Focus. Foci never came with VCT (that is unless you count the SVT Focus which btw will never work in your car) so you can be fairly safe with buying a Focus engine. Just swap the parts that don't match your car and your done. The benifits to buying a Focus engine is that there are a lot out there, plenty of those have low miles, and you get updated parts (such as the a waterpump that doesn't hide in with the timing belt).
If you do find a used year matching engine do yourself some favors before putting it in your car. Change the timing belt and waterpump while the engine is out of the car along with all the tensioners (sp?). Get a new serp belt and belt tensioner. Get new motor mounts. Inspect and replace vacume hoses and the the egr components on the engine before it goes in the car. I would even go as far as doing the radiator hoses. If you are going to drop the subrame to replace the engine (you can do it from the top though) swap out your lower control arms (LCAs). Check the suspension forums for more on that. Inspect your power steering. The Rack and pinion is prone to failure on these cars. That's not to say that yours is bad but you'll never have a better opportunity to look at it then when the engine is out.
I think you mentioned in your earlier post that your car is a 5 speed. That's great and now is the best time to replace the clutch and replace the fluid in the MTX.
Not all of this is neccesary. However, many of us would have welcomed the opportunity to do all of these things with the engine out of the car instead of having to work around the obstacles in the engine bay. If you do these things now you will be happily driving that car for quite some time knowing that you're in good shape mechanicaly speaking.
Anybody else have something to add or correct?
Jon
