Posts: 1,882 |
I have a MTX, and I've noticed something recently while sitting in a fast food drive-thru. While the car is idling out of gear with the clutch released, there is a soft rattling noise. As soon as the clutch is depressed, no rattle. Any ideas what is causing this, and should I be concerned? The car has 52K on it and runs like a top.
Posts: 6,791 |
Sounds like what you get with an aftermarket clutch... I got it with my spec clutch and fidanza flywheel. Its annoying as hell, but worth it.
Posts: 3,816 |
Ok, not to concern you... but right before my shift tower broke, I was at a Culver's in Rapid City, SD... Heard a jingling noise whenever the clutch was engaged that went away when I pushed the pedal in (clutch disengaged).
It still rattled a bit after TH rebuilt it, but not as loud as it was back in SD.
Posts: 5,143 |
Originally posted by IRingTwyce: I have a MTX, and I've noticed something recently while sitting in a fast food drive-thru. While the car is idling out of gear with the clutch released, there is a soft rattling noise. As soon as the clutch is depressed, no rattle. Any ideas what is causing this, and should I be concerned? The car has 52K on it and runs like a top.
I know exactly what you speak of... my Tour' does it too at 128K miles, its been doing it for about 20K miles... I have been informed its my throw out bearing... I am going to replace my clutch and TOB sometime soon...
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 9,872 |
Originally posted by RawBurt: Sounds like what you get with an aftermarket clutch... I got it with my spec clutch and fidanza flywheel. Its annoying as hell, but worth it.
i hate chatter from my spec clutch..but if u get spec clutch and flywheel, it'll still be there right?
Posts: 1,882 |
Originally posted by AliasJerk: I know exactly what you speak of... my Tour' does it too at 128K miles, its been doing it for about 20K miles... I have been informed its my throw out bearing... I am going to replace my clutch and TOB sometime soon...
I'm not sure how many miles it's been going on, maybe around 5-10k. The car has only been autocrossed one time, years ago, and not hard at that. So it's been babied most of its life, averaging only about 5k a year. I guess I'll just keep listening and see if it gets worse. It's barely audible, and only with the windows down. Here's hoping!
Posts: 6,791 |
Originally posted by Goonz SVT: Originally posted by RawBurt: Sounds like what you get with an aftermarket clutch... I got it with my spec clutch and fidanza flywheel. Its annoying as hell, but worth it.
Yes
