Posts: 9 |
does ne one know what my contour v6 5 sp with about 185 hp would it would in the 1/4
Posts: 2,116 |
i am guessing somewhere between 10 seconds and 20 seconds....just a guess though
95 SE MTX
svt exhaust
intake
deer killer
Posts: 191 |
Well, a 200hp SVT contour does around 15.4, so you'd probably be a hair slower than that, maybe 15.6. Really depends on your launch, and if you can drive.
Current Ride: 1998 Contour SVT - T-Red, Res. Delete, K&N under the hood, broken side skirt at passenger rear jackpoint.
Its FOR SALE, see the classifieds.
Posts: 7,025 |
Car and driver tested the non svt at 15.9 and the 170 hp cougar at 16.0. Its really hard to say what you will run depending on track conditions, weather conditions, drivers skill, etc. If its an ideal situation, then probably a 15.6-15.7.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,506 |
The stock differential has held up for some while dragging. If you are one of those who lose a diff, your ET will be substantially higher and more expensive. Reducing/limiting wheel hop might help.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 3,637 |
how do you know you have 185 crank Horsepower?
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 6,760 |
Originally posted by Tourige: how do you know you have 185 crank Horsepower?
the butt-dyno told him.
Ryan
Trollin!
