A couple of questions before these guys go on...
- Did anyone else drill hoes in the bottom of the connectors to allow water to drain? Good or bad idea?
- I'm planning on getting these powdercoated. Should I get the whole connector coated and let the installer grind off the coating where he needs to weld (then spray paint)? Or should I leave part of the connector uncoated for welding purposes...
Thanks guys
CSVT Feels Like Heaven Goes Like Hell Profile
there was some talk on getting them powdercoated, i guess it is not recomended..
you could powder coat them but then you would have to remove some of it anyway so that they could be welded on
I talked to a few people and it looks like powdercoating is out...... Leaving an area un-coated or grinding it off would just cause it to flake.
I'll paint the connectors, taping over the area that will be welded. After its done I'll jack it up and make sure everything has some paint on it...
Now what about those holes to allow water to drain?
don't think that you will need them since the ends are open and water can get out there, otherwise small ones should be ok
