Posts: 4,970 |
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 3 |
most of the mustangs are stock motors some had heads,but most are stock CR running between 7-12 PSI. majority of people have been tuning with SuperChips
Posts: 7,117 |
Posts: 638 |
Originally posted by svtProdigy: can you do that with the maanifold? because that sounds like an awesome idea.
Originally posted by TourDeForce: There would be other plumbing, wiring, & throttle cable concerns, but I suppose it could be done... I wouldn't want to be the one to do it.
Actually, flipping the upper intake is really easy. You simply unclip the throttle linkage, undo the bolts that secure it, rotate 180 degrees, bolt down and reconnect the throttle.
well... it's not quite that easy, but close, you do have to reroute the IA wiring and the TP wiring, but that usually isn't an issue, and you do have to swap a few vacuum lines, but that's not a big deal either. The only time it becomes an issue is if you are trying to maintain the smog equipment, but let's be serious, anyone putting a turbo on a fox mustang isn't worried about smog anyway since no turbo kits carry CARB EO numbers.
87 Mustang GT 5.0L TURBO
Posts: 217 |
Actually Incon had twin turbo kit for the Mustang that was CARB certified. Unfortunately they closed shop a long time ago.
George Hodge
New: Volvo S60R
Old:2000 SVT Silver Frost 1188/2150
DMD, 75mm Pro-M, HPP rear strut tower bar
Aussie 24mm sway bar (with boxed in subframe)
BAT European Handling Kit, Brullen Y-pipe
Performance Ford spherical bearing end links
Posts: 1,336 |
Originally posted by ghodge: Actually Incon had twin turbo kit for the Mustang that was CARB certified. Unfortunately they closed shop a long time ago.
I'm sure that CARB certification process went a long way to them having to close shop
