Posts: 1,055 |
Originally posted by Horse: if we can expect this kind of work then Im sure not many will be interested:
Way to route a cold side IC pipe right back next to the white hot turbine housing . . .
its all about cramming it in an engine bay.. do you think the adc kit didnt have the turbo right under the intercooler and 6 inches from the throttle body....like someone else said theres ways around it.
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 4,777 |
"cramming" in a fox body? yeah - thats like trying to cram a dodge viper in an oil tanker.  PLENTY of room to not have to do that
Posts: 1,190 |
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 2,097 |
how about this one???
or this (same set-up)
the engine/setup is just shy of 24k makes 1000hp and runs mid 9's to high 8's...hmmmm.....
98 E0 SVT with some stuff
Posts: 1,190 |
the exhaust pipe from the turbine is still hot and its going past the intercooler piping but obviously not as hot as a turbo right next to it. the set up is nice and very expensive.
#702 of 2150
Posts: 1,055 |
 man...Horse look at all that engine bay space. they shoulda twin turboed and then supercharged it...screw every having to work on it... theres plenty of space in there. forgive me I was mistaken I've never seen a 5.0 in a mustang before.....
Derek Johnson
95SE 3L gone
Posts: 3,637 |
i want a turbo
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 4,777 |
thats a different setup than the one I posted for one. Second I never said you hadnt seen a 5.OH - who hasnt??
I just said that it was not a very well designed system. And for the record - Im no turbo designer either, but I know a bit about that kind of stuff.
Posts: 533 |
Originally posted by Tourige: i want a turbo
koni kit - hpp rstb
camber/plates - cf (yikes!)
polyroll resistors - TCA's
WR headers/ypipe -TB hiflow cat
SFC's - XCal2
-dreaming of 3L-
Posts: 1,190 |
THAT NOT EVERN FORCED FABS SET UP BUT ITS MADE FROM ANOTHER SHOP AND ITS SIMULAR.
#702 of 2150
