Posts: 1,860 |
Jim -you will have to talk to ADC about that. My gut feeling is no. However the new design will be very upgradable.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 4,970 |
If the CD4E could be beefed up well enough to take 300HP/TQ with a high stall conveter, it'd make for a super fun DD in FI form IMO
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 7,117 |
Originally posted by TC'd Swazo: If the CD4E could be beefed up well enough to take 300HP/TQ with a high stall conveter, it'd make for a super fun DD in FI form IMO
I dunno if it'll take that kind of pounding at the wheels. I may find out...
Posts: 5,810 |
It should be okay with a modest turbo on a 2.5L. THe torque isn't as sudden as like nitrous or even a tough 3L. With a little progressive increase in torque it will preserve most of the components. The only concern on an ATX with higher torque loads that I would be concerned with is premature clutch pack wear. This can be reduced by installing a shift kit that allows the clutches to engage faster, reducing the slip time but makes the shift not as smooth. That of course increases the shock on the gearsets but anyways a good balance can be achieved. So I think with just a decent shift kit the atx will hold up well enough to a 230-240 at the wheels. No need to change the stall rate on the converter either.
See My Mods
Posts: 10,015 |
But the biggest issue is not having a decent diff available for the CD4E
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 4,777 |
if we can expect this kind of work then Im sure not many will be interested: Way to route a cold side IC pipe right back next to the white hot turbine housing . . .
Posts: 2,097 |
hey...you don't want it to get too cold right???
98 E0 SVT with some stuff
Posts: 4,777 |
I think they just need to get their tune . . .
Posts: 5,810 |
Yeah, not preferable but you can use a turbo blanket and heat wrap to minimize the effects.
See My Mods
Posts: 7,117 |
Originally posted by Stazi: But the biggest issue is not having a decent diff available for the CD4E
I, for one, don't plan on spinning the tires off. This is simply a project for me to add more enjoyment to my ride. The fun factor will certainly take a sharp up-turn!
