Posts: 363 |
Battery light would come on for a few minutes, then go away. Would stay off for a while, the re-appear for a few minutes. Today, came on and stayed on. DVM confirmed, running off the battery. Crap.
Well I have Ray's how-to printed off, any last minute advice before I cough up for the alternator and dive in ??
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 4,693 |
Make sure you check the in line alternator maxi fuse befor you jump into changing the alternator. It is in the wire that goes from the battery to the B+ post on the alternator. It is along the firewall, behind the coil pack on the V6.
If you have to change the alternator, have a lot of patience.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 624 |
Also the plug that plugs into the alt has a squareish metal retainer around it. If you lose this retainer the plug slides off. I replaced the alt on my SE & this was the only problem!
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
Posts: 351 |
I'll give you some advice from when i did mine on monday. Go from the bottom, use U-Joints, extentions, and don't be affraid to stick ur arm up in there to reach stuff. I did it all from underneath. Didn't do anything from up top. it was actually much easier from underneath. Just put the car on jackstands. I had a lift, but we actually only had the car about 2 or 3 feet off the ground. Good luck.
Robert
Posts: 1,029 |
Make sure you have some beer for when you're done.....you'll have earned it! It can take a while to get this job done, but it's better than paying someone else to do it. Most shops will charge lots of $$$$. Just make sure you have a bunch of extensions and swivels for your ratchet. Good luck. Scott
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 1,788 |
Don't do in in the middle of July, in the sun, and on a gravel driveway....didn't have any choice..
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 3,637 |
Originally posted by getsum111: Make sure you have some beer for when you're done.....you'll have earned it! It can take a while to get this job done, but it's better than paying someone else to do it. Most shops will charge lots of $$$$. Just make sure you have a bunch of extensions and swivels for your ratchet. Good luck. Scott
try doing headers.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 1,029 |
Maybe w/ next year's tax return. I know how bad that job sucks, but I've heard the power is worth it. Scott
Scott
Posts: 363 |
Well, I drove the car home from my folks' place and the light was on when I started the car, then after about 2 min of driving: poof. Damned thing went out !! You know, I think I am going to try changing the belt and see if that takes car of things first. I noticed too that the tensioner is near its limit for keeping tension on the belt. So maybe a slightly stretchy belt and something slippery on the belt may be the whole problem. If not I have the alternator here ready to go in.
91 Mustang LX 5.0L
Posts: 2,007 |
Only thing i would add is ...before you start...find all the bolts and spray the crap out of them with PB blaster or similar...when i did it, all of that stuff was corroded, i had to start applying so much force i was afraid that i would round out the heads...i stopped and sprayed all the bolts down a few times and waited a while for the tussin to soak in...didnt put up much of a fight after that...
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
