Originally posted by louisw: F7RZ-5486-A... they use to be like $10 each at most.
I've posted it many a time and you can go away from the stock mounts without welding or cutting by using the ProThane $12 bushing kit that is supplied with the brackets. Just get yourself a few washers and a high grade small long bolt. Put the bolt through the hole where the tab normally goes and then with washers on the top & bottom just crank your nut nice and tight, use the stock bolt for the other hole.
3 1/2 yrs and a SCA (South County Autosport) 21mm bar on Eibachs/Koni's and my subframe has not shredded itself apart. I got tired of bending brackets and was too cheap/lazy to have beefed up mounts welded in. I figured this would be a temporoary fix but it has held up unbeleivably well. Every 6-months or so I disassemble and slather the bushings with more synthtic white marine grease to keep the squeeks down.
