Page 9 of 12 1 2 7 8 9 10 11 12
#1518688 03/09/06 04:21 PM
Originally posted by Stazi:
The flex pipe installs between the outlet of the 3-bolt y-pipe and the inlet of the 3-bolt cat, and yes, it is 100% necessary.
mine should be in in the next few days..i really havent gotten on my car in fears of ya know breaking somthin..
#1518689 03/09/06 04:41 PM
0
oh ok i'm just losing my mind. there is a stock flex pipe on the csvt right? if so then i'll be fine. i kinda remember seeing one when i optimized my y- pipe but i'm not for sure. its been a couple of years since then. i'll just craw upunder the car and take a look see.
so the wpr headers and y - pipe will bolt up to my 2000 csvt with no worries right? all i need to do is pre order a set of manifold gaskets from autozone.
what kinda bolts do i need for the y-pipe to the cat connection ? and can i reuse the stock bolts for the wpr header manifold to the wpr ypipe ? i don't think i have the spring locking style bolts when i crawed under it last weekend to check it out it looks like just standard bolts and washers no spring on the headers to the y pipe.
-2000 csvt silver frost #1619 -magnaflow 14415 -optimized T/B & y-pipe -superchips xgt1 -75mm proflow maf -K&N RU-3530 -fsvt smart pump # 354Z-9H307-BC -spec stage one, LSD -low-tek,a/f,oil press.,volts -B&M short shifter -17" konig gt-r
#1518690 03/09/06 04:45 PM
98 and 98.5 (IIRC) had a 2 bolt, spring connection. After that it changed to a 3 bolt, standard connection with a flex pipe.
So you having a 00, will be fine.
#1518691 03/09/06 07:02 PM
Yea, he is right, you wont need to buy anything new except the bolts and the gaskets, lucky bastard
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1518692 03/10/06 04:55 PM
Got mine today, will post pics later...
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#1518693 03/12/06 08:55 PM
O
OB1 Offline
O
I got my tail handed to me on the install of these yesterday! I've got them on & took it to the shop today to install my mufflers, waiting on him to call now. I didn't get home until 4am this mornimg & am about to take a nap. I got a couple of pics that maybe helpful but I made alot of mistakes & found a couple of other problems that needed attention. When I wake up I'll post some of the pics. BTW my optimized Y-pipe WOULD NOT bolt up to these headers!
I don't "mod" I just fix what breaks! 98 CSVT #2527 T-Red (Limping) 98 CSVT #2228 T-Red (Donor) 98 SE Sport ATX V6 (Running again) If swimming is good for your figure, explain whales to me!
#1518694 03/12/06 08:58 PM
I told you guys that it wouldent bolt up.
On a side note, what did you have problems with? please tell me you didnt remove the alternator or anything..
#1518695 03/12/06 09:06 PM
O
OB1 Offline
O
I found a broken trans mount I meesed up cutting my EGR tube, The front O2 sensor wouldn't plug up after placing the header on(bung was on the other side). There was other stuff but I've been up since 6am yesterday morning brain is trying to shut down!
No I didn't remove the alt, But It sure looked like I was going to have to!
#1518696 03/12/06 09:52 PM
The Front upstream O2 is a real PITA to put on, i had to dremel part of the rad fan backing away to get it to work, let me tell you, screwing those thigns in is a major PITA becuase the wires spin with the o2 sensor and prevent you from screwing them in far enough.
How did you mess up the EGR? cut it in the wrong place?
#1518697 03/13/06 05:54 PM
O
OB1 Offline
O
Yeah I think I cut the egr tube in the wrong place, but I have it hooked up now just took a little extra pressure. I did the front 02 with the radiator out so it wasn't that hard & I didn't cut the fan shrouds any.
