Posts: 624 |
They sure do!  I got mine on Wednesday or so. I'll be putting them on this weekend hopefully but I still have to order some mufflers.
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
Posts: 1,238 |
No pics, but mine will be going on when I bolt in the new trans. I'll try to get a clip of them paired with my Bassani. Ive heard its sounds great.  -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 853 |
I have a two bolt flange, I want to use the weapon r y pipe, is my only option to buy a 3 bolt flange and weld it on the exhaust?
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 5,882 |
no, im not even sure that alone would work. the 3 bolt flange setup uses a flex pipe while the 2 bolt uses donut(?) gaskets. you can order a flex pipe from Bill J and then a 3 bolt flange cat from Tru bendz (or some other place). hth
Posts: 853 |
well, then i might be better off optimizing the extra stock y-pipe i have?
WR Headers GMK CAI
Posts: 3,637 |
Originally posted by BlackE1: well, then i might be better off optimizing the extra stock y-pipe i have?
if you want to use the crappy stock manifolds... yes.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 853 |
Originally posted by Tourige: Originally posted by BlackE1: well, then i might be better off optimizing the extra stock y-pipe i have?
I have a complete set of weapon r headers i will not be using stock manifolds...
I am talking about the Y-Pipe
WR Headers GMK CAI
Posts: 624 |
People say that the Weapon R Y has different dimensions, so what he's saying is that the stock Y won't bolt up! I don't know but I read this somewhere recently, I'll find out this weekend for sure!
Posts: 533 |
i just arrived home to have a WR box sitting at my door. friggen UPS bashed it around like a pi�±ata. few dins in the headers part. could have used better packaging. i bet they sound sweet
-a
koni kit - hpp rstb
camber/plates - cf (yikes!)
polyroll resistors - TCA's
WR headers/ypipe -TB hiflow cat
SFC's - XCal2
-dreaming of 3L-
Posts: 4,051 |
Originally posted by BlackE1: Originally posted by Tourige: Originally posted by BlackE1: well, then i might be better off optimizing the extra stock y-pipe i have?
Stock y-pipe will not bolt up to the Weapon R headers.
