Posts: 853 |
so then how haven't i broken anything yet with out a flex pipe, if the two bolt flange is not the flex joint??
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 10,015 |
The 2-bolt flange WITH the donut gasket AND the spring bolts IS a flex joint. Just a flange to flange connection obviously isn't.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 3,637 |
Originally posted by Stazi: The 2-bolt flange WITH the donut gasket AND the spring bolts IS a flex joint. Just a flange to flange connection obviously isn't.
That and the stock Manifolds are so damn think i dont see how you would crack them.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 10,015 |
Yeah, yo'd break the studs in the head instead!
AUSSIE ENDLINKS $70
Posts: 343 |
So I have a 1998 Ford Contour SVT, so i dont have a stock flex pipe? I am installing headers, so where can i pick u a flex pipe and what size is it and such??
would this work????
Flex Pipe
Also where do i mount the flex pipe? I am not too familiar wiht the setup on the SVT exhaust so in order what components do i need from the engine back?
I have another problem too.... my stock cat is a 2 bolt flange (1998 svt) and my new y pipe from WR is going to be the 3 bolt flange.... so what shall i do about that?
Posts: 425 |
hey i've found a great ebay company that sells the flex pipe for the v6, for cheap. here's the link, http://www.exhaustdirect.com/
1998 Ford Contour Se 2.5 litre Silver frost
Posts: 1,087 |
Originally posted by ContourSVT93: So I have a 1998 Ford Contour SVT, so i dont have a stock flex pipe? I am installing headers, so where can i pick u a flex pipe and what size is it and such??
would this work????
Flex Pipe
Most likey you don't have a stock flex-pipe, but rather the "donut"-style flex gasket. What you need to do is either buy a cat with a 3-bolt flange along with a 3-bolt flex-pipe, or buy the 3-bolt flex-pipe and have an exhaust shop weld a 3-bolt flange on your current cat/test-pipe in place of your 2-bolt flange. The flex pipe goes after your Y-pipe and before your cat. I would recommend just ordering a Hi-Flo 3-bolt cat from Tru-Bendz and then get the 3-bolt flex-pipe since it would be dumb to have a crappy stock clogged cat right after your nice flowing headers.
Matt
2002 Subaru Impreza WRX (WRB Stage 4+)
Old Rides:
1999 Sil-Fro SVT Contour 3.0L with goodies (Totalled 6/21/06)
1988 Bronco II (Sold)
You know you launch hard when you beat oncoming traffic through their own crosswalk lines.
Posts: 9,872 |
dont forgot the 2 gaskets for the flex pipe for each end..
part # F5RZ-5E241-C
Posts: 3,637 |
Originally posted by Goonz SVT: dont forgot the 2 gaskets for the flex pipe for each end..
part # F5RZ-5E241-C
If you guys want ill make a Weapon R FAQ and GTO pete can Sticky it, there have been so many posts latly..
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 9,872 |
Originally posted by Tourige: Originally posted by Goonz SVT: dont forgot the 2 gaskets for the flex pipe for each end..
part # F5RZ-5E241-C
werd
