Posts: 22 |
i goofed haha 97 tour oops
97 contour SE 2.5 duratech
Posts: 49 |
'99 SE Sport V-6 5 speed 73,XXX
Rear wheel bearing EGR passageway cleanout to clear Check Engine light for "insufficient EGR flow" Oil pan gasket Broken front sway bar bracket Busted sunroof motor (not fixed) Regular maintenance, brakes, struts
Posts: 6,791 |
1999 SVTC, 110k
wheel bearing (2) alternators battery Brakes Struts Springs Differential
Probably some other things as well
Posts: 110 |
00 Mystique LS V6 Atx, 53Kmiles, 2nd owner, regular maintenance only. Changed the TUBE ASSY-CRANKCASE only.
00 Mystique LS V6 ATX
57K miles
K&N air filter
TH Fix
B&M 70268 Atx cooler
Posts: 771 |
1999 Mystique LS, 2.5L, Auto 196,000 miles nothing replaced other than fluid, filters, tires, sparkplugs, front brake pads @ 105,000 mi.
original waterpump original sparkplug wires original rear brakes original PCV valve never have cleaned throttle body consistently 30 mph on highway
-Mark-
'99 Mystique LS, totally original (including the original water pump and the premium stereo)! Bought new in December 1998 for $21,000.
208,000 miles
Posts: 618 |
98 SVT 152345
Replace list- too long to post. Stock internals and tranny though.
E0 SVT
Kids, yeah, I have kids. How many do you want?
Posts: 993 |
98 SVT Contour original owner approximately 382,000 Km converts to about 237,400 miles give or take a few. I am not 100% sure what my exact mileage is as my speedo died on me at the end of year last year and I drove it for about a month with it not calculating mileage. Still lovin the car.
I have done:
wheel bearings a few times in the front rear wheel bearings once clutch third gear syncro brakes including new rotors and calipers water pump (long time ago) new speedo regular stuff like plugs, wires, oil changes etc. There is probably some other stuff to but I cannot recall off hand.
1998 BLK SVT CONTOUR
#2980 of 6535
395,000(ish) km (and counting)
SVTOA-TORONTO
Chapter Director
www.svtoa-toronto.ca
Posts: 3,788 |
98 SVT with 87,000 miles. Second owner. 02 sensor, bank 1 Preventive maintenance: metal impeller WP new belts UIM/LIM cleaning Spark plugs/wires Trans. drain/refill coolant flush brake fluid flush
Posts: 1,029 |
111k miles. I have replaced:
Transmission(diff,axle broke) Alternator Springs and struts Front wheel bearing.
Other than that, just basic mods because I wanted to, not because I had to. Scott
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
We really need another one of these threads!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
