that same wire is in a loom next to your passenger side strut tower, between that and the engine, someone has a pic, damn i need a digi cam... hope this helps... DONT FORGET TO GROUND IT to the o2 sensor ground, grounding it to your frame, from what i've deducted, will lean your car out and screw up the readings of the gauge. did on my car anyhow...
