bozman Offline OP
my problem is that I have installed my volt and oil pressure and am down to installing the air fuel ratio and i need to know what wire is the sending wire can anyone help
thanks
98.5 SVT CONTOUR silver 17 inch white rim's and touring wing lowered and custom interior paint
intake and gage pods
F
F
Its the red and white wire running from the front O2 sensor, right behind the raidator. Hope that helps.
98 Mystique LS BLK V6 ATX and my bald head behind the wheel.
mods so far:
SVT Exhaust
215/60R15 Potenza RE950
Pioneer Premier DEH-P520 headunit with XM Radio
BNMotorsports gauges
KKM Intake
SVT side skirts
A pillar gauge pod with Volts, Oil Pressure. and A/F Ratio
that same wire is in a loom next to your passenger side strut tower, between that and the engine, someone has a pic, damn i need a digi cam... hope this helps... DONT FORGET TO GROUND IT to the o2 sensor ground, grounding it to your frame, from what i've deducted, will lean your car out and screw up the readings of the gauge. did on my car anyhow...
-Speed Demon- Matt
Black 2000 Contour SE Sport (duratec/atx)
got body mods?
all show, better than stock go smile
"I might be crazy, but I'm not stupid"
speddmn.com
