So I got some struts off a taurus and finally found all the hardware I needed to do the instal.
Well while working on the hood and drilling out the hood mount screw and tapping it I've enountered the worse thing possible. The tap sheared in the hole and is stuck right in place. The material used for the tap is so hardened that bit after bit after bit after bit just dulls out trying to drill it out.
Now I'm left with a hood with 1 strut installed on one side and 1 screw ont he other side and a bummed hole.
I've contacted IRWIN (the manufacturer) about a claim since this was a brand new bought today bit and tap kit. Thus the hole I was tapping was the perfect size because the bit I used before tapping it was from the same kit.
This just sucks, any suggestions?
