All ?'s are in the FAQ's
1) No 3.0 TO Bearing/Slave. So that makee it easy, huh?
2) Cut the bushing flush to the flywheel mounting hub
3) When you put the COntour alt bracket up to were it should go you'll see which ones get cut off.
If it's a full 3L engine, one off the head, one of the block.
