dgodard Offline OP
Hi guys, i had a little problem with car today, here are the facts:
Today's temp was 90F and my car is a 00 mystique V6 ATX with 52k miles.
I was driving in D in a downhill(AC was on), switched to N and car started to accelerate itself till 2krpm and drop to 1krpm an so on, when car is stopped at red light in neutral revs stayed at 1krpm, in D stayed at 750rpm....if car is moving (5mph) in Neutral car accelerates itself and goes crazy. I didn't get any CEL or anything. If car is in D and suddenly i stop car looks to keep accelerated a while.
Anyone has any idea about this? sounds to you like an IAC problem? TSS? Throttle Hang?
I'll appreciate a lot any input
00 Mystique LS V6 ATX 57K miles K&N air filter TH Fix B&M 70268 Atx cooler
Originally posted by dgodard:
...Anyone has any idea about this? sounds to you like an IAC problem? ..... Throttle Hang?
Yes and yes. MOOSE.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1179824&Forum=trouble&Words=moose&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=1week&Main=1179062&Search=true#Post1179824
dgodard Offline OP
Thanks Tony, i'll do TH fix and clean IAC to see if it gets better, only doubt i have is which size of hole do i need to drill in the 1/2 inch copper pipe cap?
Start with the smallest hole suggested then enlarge it if needed since it's pretty hard to make it smaller if you get it too large.
Steve
I have a 2.5L non svt v6 and I drilled mine 15/64. It worked great. Buy a few 1/2 copper pipe caps, and try a few sizes. You decide which is best for your car! They're less than 25 cents a piece. Good luck!
For Sale - 96 Tour Sport 2.5L MTX with SVT Exhaust, pre 98 trunklid with newer Contour Sport spoiler instead of lip spoiler, newer Contour sport rims. Newer paint job. Brand new floor mats. Rust Free! PM me for details and pics.
dgodard Offline OP
Thank you! I'll start trying same size as you did
