Posts: 185 |
Well I might have just had my worst experience with bosh ever. But I don�t blame them for all of it. So here is what happened. As I was putting the spark plug in to hole 6 today just as it got tight I mean I didn�t have barely any force on it. It broke off just above the nut. So right now I got half the plug in the motor and half in my hand and I was wording what I can do to get this thing out short of pulling the head. Is there a tool out there for such a problem what can I do? HELP PLEASE
Mystique 98 ls T-red
MTX
B&G springs
Turbendz y-pipe (running test pipe)
Trubendz cat back with flowmaster muffler
Costume intake with K&N filter
B&M shifter
Magstar wires
Posts: 5,143 |
Originally posted by skifast87: Well I might have just had my worst experience with bosh ever. But I don�t blame them for all of it. So here is what happened. As I was putting the spark plug in to hole 6 today just as it got tight I mean I didn�t have barely any force on it. It broke off just above the nut. So right now I got half the plug in the motor and half in my hand and I was wording what I can do to get this thing out short of pulling the head. Is there a tool out there for such a problem what can I do? HELP PLEASE
I guess I dont quite understand... if it broke off right above the nut then you should be able to just thread it out with the socket wrench right? But if the bottom half of the plug broke and feel into the motor, then you can pick up a magnet tool from Autozone, its a very powerful magnet on the end of an antenna like extendable pointer, very useful in these applications.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1,238 |
Also make sure you get all the little pieces of porcelien out too. That could be bad. -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 1,593 |
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 410 |
If you have a shop-vac, Take the valve cover off and create a good suction on the plug hole to get contaminates out. If its broken above the nut, why can't you just un-thread it?
95 Contour GL. Bought new.
BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids.
Looking for 15" alloy rims-PM me.
180,500km's so far.
Posts: 185 |
i guess while i was hitting my self with the socket wrench i must have typed it wrong i ment to say it broke off below the nut. now short of pulling the head of valve cover off. what do you all think i should do
MTX
B&G springs
B&M shifter
Magstar wires
Posts: 410 |
You might get lucky with an "Easy-Out". I've never drilled a spark plug before. Start with a smaller size and go from there. If you can't get the debris out of the cylinder, your taking the head off. If you drill it straight in the plug, it should come out. At least it's the front of the motor.
180,500km's so far.
Posts: 185 |
god lord your right about the fact that its one the front. ohh well i guess ill give this easy out a shot. my dad AKA man of all tools. says he goes some but i have never used it befor [censored] idk what it looks like so any one got any pointers. also any other ideas would be cool
MTX
B&G springs
B&M shifter
Magstar wires
Posts: 185 |
has any one ever had this happen to them? im like sick over it i cant stand it when stuff happens to my car.
MTX
B&G springs
B&M shifter
Magstar wires
Posts: 2,408 |
Originally posted by skifast87: has any one ever had this happen to them? im like sick over it i cant stand it when stuff happens to my car.
Have not seen this one in years.
Use a torque wrench on plugs in aluminum heads!
Use antiseize on plugs in aluminum heads!
Inspect the threads carefully when you get it out, if the threads are damaged you need to put an insert in to restore the threads.
