Page 1 of 3 1 2 3
#1515363 03/01/06 04:17 PM
9
95cgl Offline OP
9
Hi,
This is my ride 95 Contour GL 2.0L 4Cyl. 98,330 Miles
Just waxed with meguiars NXT wax blacked tires with Meguiars gel and blacked trim with Mothers Back to Black.
Meh. not to bad..
Meh...
but looks arent everything.. need to run head gasket sealer though it and replace a/c accumulator..
but the point of this post was to ask your opinion on how to detail it out more like the right rear wheel is all scratched up (this way when i bought)
ICK!
How do i fix that without buying new?
Also there where a few scratches on the paint and chrome when i bought it..
Keys scratching paint (appears to be)
Some IDIOT slammed door into her?
Chrome scratched some how DUM dog or cat maybe?
And headlights are yellowed i have read about sanding them but this just does not seem like an intelligent thing to do... I also seen where transmission fluid does the trick but haven't tried.. i tried putting the NXT wax on them shined them up nice but did nothing for yellow..
EWWW!
Any ideas?
95 contour 2nd owner Miles: 98,800 Transmission: Automatic Engine: Zetec 4 Cylinder 2.0L Significant Problems: Wiring Harness (cracking!!)
E
E
Looks pretty good.
Why doesn't the headlight sanding seem "intelligent"? It works! You are using very high grit sandpaper (1000 +) and really only taking the damaged (yellowed) layer off.
I know there are many that swear by this method. I've done it a few times myself, works great!
I doubt there is much you can do for that wheel cover. Probably best just to replace it, if it bothers you. Check out a junkyard, or ebay...
Good luck!
MUST SELL - ECM computer new for a 98 V6 mtx + pats Now trolling in a Red Nissan 4 x 4
Originally posted by mean'tour:
Looks pretty good.
Good luck!
Or if you want to do a mod, im sure someone has some nice aftermarket rims and tires for sale in the classifieds.
9
95cgl Offline OP
9
thanks.. i might check the junk yard..
what about chrome? would chrome wax work?
I would just paint the chrome.
I agree. Paint the chrome strip on the rear bumper body color. I noticed that there is no chrome strip on the front bumper.
'98 Contour Pacific Green(Modded) http://www.cardomain.com/ride/676416 FS:'98-00 Contour front bumper.Brand new unused (Non-SVT)
Heck, just remove the chrome piece and clean the part it was glued on. I did that and it looks 10,000x better than the cruddy chrome on it.
The hubs, your better off replacing them w/ another set of hub caps or upgrade to rims. If you go to the juck yard see if you can salvage any of the E0 or E1 rims from another contour/mystique.
My ride(Cardomain link) : '95 Contour 16V Zetec DOHC, Teal , ATX Born on Sep. 4, 1995 86+ miles *LEDs mods are on their way!*
How did you remove the chrome strip? I really need to do that as mine are a hfge eye sore cause theyre poeeling and flaking off.
95 LX-with a mind of its own 24v DOHC SVT exhaust and K&N=all thats worth modding Go Fighting Sioux!!!
Y
Y
Looks to be a really clean pre-98! If you're hell bent on keeping those wheel covers, get yourself a multi-pack of sandpaper, some primer, aluminum wheel paint, and some clear coat. Sand the bad areas down from lowest grit to highest until smooth. Shoot the areas with primer(2 coats). Then shoot them with the wheel paint. I'd do 2-3 coats, 24 hours apart. Once they're dry, do a few coats of cleacoat. SHIZZAAAAM, brand new wheel covers. I had to do this with the center caps on my SHO.
Mark
Page 1 of 3 1 2 3
