Posts: 86 |
whats a good way to cut the shifter? Im trying to think of good clean ways to do it. Anyone?
1998 Contour Svt Born 5/12/97 #897 of 6535 Those who think, are conquered, Those who act, conquer.
Posts: 515 |
Might wanna try this in the "transaxle" thread...just a thought
Oh, and bad idea to just cut the shifter...I'd be a lot better decision to either get the B&M shifter or the Steeda...Search around a bit and you'll find your answer
Posts: 536 |
Originally posted by owen_SVT: Might wanna try this in the "transaxle" thread...just a thought
only if you have a post-98
what are you supposed to do if you have a pre-98
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 4,051 |
Originally posted by striker2: Originally posted by owen_SVT: Might wanna try this in the "transaxle" thread...just a thought
fordsvt98
Hmmmm....
Posts: 536 |
Originally posted by CSVT1214: Originally posted by striker2: Originally posted by owen_SVT: Might wanna try this in the "transaxle" thread...just a thought
fordsvt98
Hmmmm....
yeah but im sure ther are some guys with pre98's that would like some ideas
like me
97 contour gl mtx
19mm bat sway bar
Posts: 515 |
well since you hadnt posted anything reguarding it, my reply was in reguards to fordsvt98  ...oh, and thanks Tony lol
Posts: 536 |
yeah i didnt see his name until after i posted otherwise my post might have been a little different
97 contour gl mtx
19mm bat sway bar
Posts: 515 |
Not a big deal haha...But a few posts that ive read is that all you'd need to do is cut the shifter and use a die, otherwise just use a non threaded shifter...Also to get rid of the reverse lockout you could take the cable and pull it tight so it seems that the reverse is always pulled and just tack it to the shifter itself...That way you dont need to get under the car to completely remove the lockout...Someone please correct me if im wrong though!
Posts: 536 |
Originally posted by owen_SVT: Not a big deal haha...But a few posts that ive read is that all you'd need to do is cut the shifter and use a die, otherwise just use a non threaded shifter...Also to get rid of the reverse lockout you could take the cable and pull it tight so it seems that the reverse is always pulled and just tack it to the shifter itself...That way you dont need to get under the car to completely remove the lockout...Someone please correct me if im wrong though!
thats kinda what i was thinking
97 contour gl mtx
19mm bat sway bar
Posts: 3,637 |
Buy a 97+
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
