#1514708 02/28/06 07:42 PM
lizard Offline OP
if i get the engine bored .030 over will there be any noticable performace gain from that?
2000 contour V6 ATX BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
#1514709 02/28/06 08:07 PM
OMG. Please stop all posting and search. The gain in power will be negligable. Also where are you going to get pistons for it? If you want gains the 3L is the way to go. You have a POS ATX so you only option is TO GET RID OF IT AND GET AN MTX. You can't sqeeze blood out of a turnip.
#1514710 02/28/06 08:20 PM
lizard Offline OP
accurate engine has pistons for it and i dont have money for a manual yet and personally id rather get a turbo 2.5 than a 3L more high eng power.
#1514711 02/28/06 08:32 PM
And a turbo has to do with what? We'd all like one but most of us don't see the logic of putting a 5k turbo kit on a 5k car. You can't afford an MTX for a few grand but have turbo pipe dreams. Pun intended. So who is going to bore and hone and build this engine for you? You know how much it is going to cost to have this done? As much as buying another running Contour.
#1514712 02/28/06 08:40 PM
Dumbass alert.
#1514713 02/28/06 08:42 PM
Captain Impound Boy
Captain Impound Boy
Ill bore and hone it..
He gets the same killer deal the V8 RWD guy gets... 6K in labor
#1514714 03/01/06 03:31 AM
NO!!!!!!!!
.030 is a clean up bore. If you get a 1% power increase you would be lucky.
You do the math. Calculate the engine displacement with the .030 overbore and then calculate haw much it increased the displacement over the stock bore. Then determine the % increase in displacement. That would be the maximum increase assuming everything else stayed stock.
#1514715 03/01/06 12:26 PM
About 1.85%. Assuming you did a 0.030 overbore, shaved the heads/thinned the gaskets as much as possible (before something hits inside!) to boost compression, matched rings to cylinders/pistons, and all those other little tweaks that they do to race engines...
Maybe ten horsepower. And I mean maybe, you'd be very lucky to get that. And that kind of engine work would run you several grand (despite parts costs being ~0). So lets say at only $1000 (a smokin' deal!), that's $100/hp: and that's highly optimistic! Now, a 3.0L, on the other hand, would get you ~30-40 hp for not much more money: being very conservative, it's $100 per hp. More likely you'd pay $500/hp for boring, etc., and $50/hp for a 3.0L.
It's just not worth it, eh?
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
