Cold startup - ~100 psi
Warm idle - 40 psi
Warm cruising @ 3000 RPM's - 65 psi
Warm WOT - 90 psi
Mechanical oil pressure gauge tapped into the remote oil filter kit (in line between block and FLA1 filter)
I was reading on NECO guys are getting like 15psi at idle, 60 at WOT
Looks the same as mine.
When I fire mine up it buries the needle. I believe mine is the same as yours and thus it is normal...
Ryan Trollin!
Warm idle - 40 psi
Warm WOT - 90 psi
If he is getting 15 psi at startup...he has prob tapped the head...
Sweet, thanks dudes
That sounds like a good assumption.
Y
Y
That's if he said at startup. He said at idle. At startup, my gauge will pretty much bury itself. After some cruising around, and I come back down to idle, it sits under 10psi.
Unfortunately, my needle broke late last year, so I will have to send the gauge into Autometer to have it reattached. Not sure what it'd read, if I were driving it that is.
Mark
I tapped just before the oil filter in the block and my numbers are very similar to yours...
2000 Cougar V6 MTX 2001 3.0L Swap w/ PnP Heads - It ran, it boomed, it RUNS AGAIN Nearly all suspension mods Big ass stereo ...and more... See Her Here
