Posts: 3,570 |
Cold startup - ~100 psi Warm idle - 40 psi Warm cruising @ 3000 RPM's - 65 psi Warm WOT - 90 psi Mechanical oil pressure gauge tapped into the remote oil filter kit (in line between block and FLA1 filter) I was reading on NECO guys are getting like 15psi at idle, 60 at WOT
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,760 |
When I fire mine up it buries the needle. I believe mine is the same as yours and thus it is normal...
Ryan
Trollin!
Posts: 9,065 |
Originally posted by rkneeshaw3.0: Cold startup - ~100 psi Warm idle - 40 psi Warm cruising @ 3000 RPM's - 65 psi Warm WOT - 90 psi
If he is getting 15 psi at startup...he has prob tapped the head...
Posts: 3,570 |
Posts: 9,602 |
Originally posted by MapOfTaziFoShoâ�??¢: If he is getting 15 psi at startup...he has prob tapped the head...
That sounds like a good assumption.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 6,106 |
Originally posted by DemonSVT: Originally posted by MapOfTaziFoShoâ�??¢: If he is getting 15 psi at startup...he has prob tapped the head...
That's if he said at startup. He said at idle. At startup, my gauge will pretty much bury itself. After some cruising around, and I come back down to idle, it sits under 10psi.
Unfortunately, my needle broke late last year, so I will have to send the gauge into Autometer to have it reattached. Not sure what it'd read, if I were driving it that is.
Mark
2000 Black CSVT
Posts: 317 |
I tapped just before the oil filter in the block and my numbers are very similar to yours...
2000 Cougar V6 MTX
2001 3.0L Swap w/ PnP Heads - It ran, it boomed, it RUNS AGAIN
Nearly all suspension mods
Big ass stereo
...and more...
See Her Here
