Page 2 of 3 1 2 3
#1514323 03/01/06 02:31 AM
My 95 GL has the same hissing cap. It allows preasure to blow off and not stress the system so much. Mine never boils over and its the origional.
95 Contour GL. Bought new. BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids. Looking for 15" alloy rims-PM me. 180,500km's so far.
#1514324 03/06/06 02:38 PM
yeah thougth about that, the hissing being the release of pressure and its designed to do that. well now i have white smoke coming from my exhaust when i start it up and it has an anti-freeze smell to it, i've lost some antifreeze from the tank. i've looked at 3 of the 6 spark plugs and they are clean of anti-freeze and oil so thats a good sign and the dip stick doesnt have anti-freeze on it either so im encouraged that it doesnt seem like a blown head gasket right now. any ideas? im thinking about putting my old reservior tank back on with the pressure relief tube on the back of it and use the new cap and see if that helps maybe.
Mike 99' Silver CSVT 95' Silver Acura Integra www.latest-craze.com
#1514325 03/06/06 03:14 PM
Doesn't matter what tank you're going to put on. Coolant doesn't magically get into the engine.
#1514326 03/06/06 03:31 PM
Todras, so are thinking blown head gasket? Or could it be something else?
#1514327 03/06/06 03:34 PM
If it had a blown head gasket it would most likely misfire on top over heating.
#1514328 03/06/06 04:12 PM
Here is a cheap quick way to test the headgasket.
Fill antifreeze to the brim on recovery tank (leave cap off). Remove all spark plug wires. Remove all but one spark plug and have someone crank the engine. If the antifreeze bubbles over, there is leak from that portion of the engine (or cylinder). If not, go to the next cylinder, and then the next.... Note, it could be more than one area or more than one cylinder. Good luck
#1514329 03/06/06 04:15 PM
When the old tank was on, I would drive to work (25 min drive), then when i would get off the exit and make it about a mile down the road, my temp would rise and i would give it one good punch on the trottle while in neutral and it would go back down to normal, but since i've changed tanks, no problem like that, one had maybe 2 instances where i felt the car may have mis-fired, but i wasnt looking for it and honestly wasnt paying attention to the car itself to "catch" the feel of it when i thought it might have mis-fired. spark plugs were just replaced last week as well just as an FYI (well after the couple times i thought it might have mis-fired). this much smoke shouldnt come from the car when its first started and then go away after a couple min.
#1514330 03/06/06 04:18 PM
Thanks Tony, but wouldnt the cylinders that dont have plugs in them fill up with fuel?? wouldnt that be hard to start later???
#1514331 03/06/06 07:25 PM
Originally posted by LCraze777:
... wouldnt that be hard to start later???
My concern would be a leaking headgasket. In any case, if there is too much fuel in the cylinder after the test, you could always push the gas pedal all the way to the bottom and crank it (closes the injectors). That would usually start it up.
#1514332 03/07/06 12:11 AM
Sounds like a Head Gasket. Coolant level going down.
Anti-freeze out the tail pipe?
Temps being eratic?
I would stop driving it as to avoid warping the head(s).
Page 2 of 3 1 2 3
