Posts: 11 |
I was wondering what the best way to fill in scratches and dings would be. Would it be using one of those fill in pens(i think thats what they call them) or is there anyother way... Thanks
Posts: 2,659 |
yeah you can use those pens but how good will it look. I have never used them myself. How bad are your scratches?
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 11 |
the scratches arent too bad.. none of them are really deep they are all just surface scratches.
Posts: 75 |
use a clay bar (local auto store) it gets all the surface scratches and outer buildup off, it's sorta like a new start. You have to wax afterwards though, it basically strips everything. hope that helps, there's a good one called Mother's california clay bar I believe it's called for about 16.99. it will last you forever! give it a try
'96 Mystique (Performance Wht/Zetec)
few mods
'65 Ford Mustang V8 <3
'85 Caddy Eldorado AKA Pimpmobile lol :P
Posts: 1,746 |
If you have pretty deep chips, that tinted turtle wax polish is pretty good for a temporary fix. You really have to slop it on to get it to fill the chips.
Posts: 499 |
ScratchX from Meguiars works pretty good at getting light scratches out by hand. I detailed a car last year that had dog claw scratches on it. After a couple of applications they were gone! I believe it costs ~ $5 and can be found at WalMart/KMart. Give that a try before you do the colored wax routine.
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
Posts: 1,746 |
Scratch-X isn't going to anything for chips down to the primer, hence why I stated deep chips.
Posts: 499 |
Originally posted by Jason43: Scratch-X isn't going to anything for chips down to the primer, hence why I stated deep chips.
Correct, but the original post was about fixing scratches, no mention of them being down to the primer.
