Posts: 2,659 |
Originally posted by RawBurt: Originally posted by Tourige: I love these threads, it always starts off great, and then someone comes and whips out a big handfull of reality.
DROP THE TOOLS AND STEP AWAY FROM THE CAR!
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 4,140 |
Originally posted by Mytourburnsrice: Or do something else? And if something else, what?
If you want a fast drag car, get something else and build that up. This chassis just doesn't have what it takes to be crazy fast in the 1/4 mile.
If you like the Contour, but want some real power, do a 3.0L swap. If that's not enough, put a turbo on the 3.0L engine. Whereas the 302 would be a project of Biblical proportions (think about putting a pyramid into Noah's ark ), the turbo 3L has been done, and the bugs are worked out. If you're good enough to swap an engine that doesn't even come close to fitting, a 3L turbo could be done in a few weeks. It'll cost much, much less, look stock, go like stink, and not be any harder that the stock car to fix.
Certainly, there are interesting things you can do that have never been done, but you can really get all the power you could ever want this way. With a lot of work, 500 fwhp is almost certainly possible. 300 fwhp is cheap and almost easy. And those aren't dyno queens, you can get a reasonably sized turbo to peak at 300hp and have a great flat torque curve.
Why bother with anything else when you can have that? Just keep it stock looking, so they'll never know what hit 'em when you show up and run low 13's all night.
Posts: 347 |
Ok to all the haters/doubters  There is a guy in the UK who is doing a RWD V8 conversion. On a Mondeo. Yes, thats right. Here is the link. http://www.fordmondeo.org/forum/showtopic.php?tid/689585/hl/rear%5C%7Cwheel%5C%7Cdrive/tp/3/I am not sure where he's at right now, but I should message him and find out!
1996 Mondeo 24v 4-door
twin janspeed stainless pipe
cat by-pass
Phase 2 RS bodykit
16" cosworth alloys
K&N RU3530
SVT TB/UIM/LIM
poly bushings
konis/bat springs/bar
Pioneer
MSDS
Indiglos
P&P heads
2005 Mondeo Zetec Tdci
Posts: 2,116 |
you can do ANYTHING with enough time and money
95 SE MTX
svt exhaust
intake
deer killer
Posts: 121 |
d^mn right you can, and i support anyone trying this.
1999 SVT
removed res
FMS 9mm
metal impellar
Koni struts
PG Xenon 6.5
MSDS Y-pipe
Posts: 2,097 |
Originally posted by mySVT: d^mn right you can, and i support anyone trying this.
What does that mean? You donate money to the cause ...or you sit back and cheer?
Seriously though, there are so many that say they will do this and that....talk's cheap.
98 E0 SVT with some stuff
Posts: 9,872 |
Posts: 7,117 |
Originally posted by stilov: Originally posted by mySVT: d^mn right you can, and i support anyone trying this.
Easy now. Give the MEG boys their props for at least getting started. They're already father along than anybody I've seen...
Posts: 21,653 |
I like their use of boards layed across scaffolding to support the front end of the car.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 9,065 |
Originally posted by SVTfrog: I like their use of boards layed across scaffolding to support the front end of the car.
I had no idea they had camaros over there!
