Posts: 9,872 |
Originally posted by Stazi: Yes you can buy nmy standard CSVT kit from me, then when the big-brake upgrade is made available, all you would need is new front FSVT rotors (also available from me) to completethe upgrade.
excellent!!
Posts: 4,639 |
hopefully i'm getting this right and not sounding like a broken record.
this will use the csvt calipers and pads front and rear? csvt front rotor goes to the back and fsvt front rotor goes to csvt front. ss lines recommended.
so whats the benefit of going with the fsvt front kit? does the fsvt use larger calipers with better pistons and larger pads to sweep the 300mm rotors better? will the csvt pads be big enough to sweep the larger rotors (front and rear). so once the kit is completely installed and worn out, then we'll go shopping for csvt front/rear pads as we would now and csvt front rotors for the back and fsvt front rotors for the csvt front. i think this is right, right?
Hugo AIM:omegazodiac
Posts: 759 |
Originally posted by hmouta: hopefully i'm getting this right and not sounding like a broken record.
For a CSVT: Purchase FSVT front rotors and custom brackets. FSVT - Install FSVT front rotor with stock CSVT calipers using custom bracket. - Install CSVT front rotor on rear with stock rear CSVT calipers using custom bracket. - FSVT front caliper is the same as CSVT front caliper. The benefit of going with the larger rotor: increase in diameter will increase the braking torque (even with the stock calipers), larger surface area will help cooling and decrease fade. - SS Lines are recommended.
Posts: 9,602 |
Originally posted by mamisano: - FSVT front caliper is the same as CSVT front caliper.
Incorrect. The SVTF caliper is slightly larger and mounts differently. (thus requiring a special "SVTF" bracket)
Also for the record - All CDW-27 rear disc brake components are the same. They are not SVT specific. (well the stock SVT rear rotors supposedly had a "dacromat" finish)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 4,639 |
ok got it. so price wise and i dont race the car, going to fsvt calipers isnt really needed. csvt calipers with fsvt rotors will be fine for street driving.
Posts: 439 |
Is this ever going to happen?
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View project Slippery Slope
Posts: 338 |
Originally posted by ohsigmachi: Is this ever going to happen?
I'm in no hurry but would like to be put on the list of "PM as this progresses further" as it sounds like a good cost efficient upgrade for those of us who don't NEED a big 13" brake upgrade but would rather just stop a little cooler and easier
If/When this comes available i will be in on a full set of new pads, all hardware/brackets, and most likely the FSVT Rotors
CSVT#1321/2150 Born 1/6/2000
It's just a Contour..
Before Dyno: 178.9whp w/2.5L
94 Probe 4cyl/150k KYB struts, Magnaflow Polished SS muffler (Daily Driver)
Posts: 439 |
Ordered my TCE kit today, so I guess I'm out...
Posts: 5,600 |
Well to be honest if I had the $$$$ I would get the TCE anyway. Besides the lighter wallet, youre better off.
Black 1998.5 CSVT
Posts: 3,637 |
ill probably do this, seems like a good idea and i dont think it should be to pricey.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
