Posts: 1,423 |
Originally posted by Stazi: Originally posted by scottd60:
Stazi,
I realize that this kit is for SVT front rotors on the back and FSVT front rotors. My question is for us guys with Baer 13" (330mm) front brakes would the FSVT front 300mm rotors be a better match for the rear instead of the 280mm SVT rotors? Just thinking down the road
Thanks,
Scott
I wouldn't say that. Sure with BAER$'s you get more front bias, but I wouldn't downgrade from BAER's to FSVT's. Just the rear kit, for guys with your setup, will bring the brake biasing closer to what it should be.
You missunderstood me...I think. I'm asking if I put the FSVT 300mm front rotors on the rear and keep the Baer 330mm's on the front. That would give me 330mm front and 300mm rear (would need a different adapter bracket to do this) but would the biasing be close to where it should be?
Scott
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 6,106 |
Is it as easy as matching the percentage difference between the front and rear rotor sizes on a stock car?
SVT = 280mm front rotors and ???mm rear rotors (???/280 = X.X% difference in size) BAER = 330mm and FSVT = 300mm (300/330 = 9.1% difference in size)
Wouldn't you want to come as close matching the percentage difference that comes from the factory?
Mark
2000 Black CSVT
Posts: 6,760 |
Originally posted by SteedaSVTââ??¢: i just want it in the rear and Stazi knows that.
wow.
Ryan
Trollin!
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Originally posted by RTStabler51: Originally posted by SteedaSVTââ??¢: i just want it in the rear and Stazi knows that.
wow.
Sorry Ryan you where already taken by one of your Marine buddies,
Posts: 10,015 |
Guys to run FSVT's in the rear will need a different bracket again, and frankly I think it would start looking a little ridiculous seeing as the actual swept area on the FSVT rotors, buy a stock rear pad would be patheticly thin compared to the diameter of the rotor.
I will guess that Tom won't want to make an even larger offset bracket.
And if it were me making the brackets, I wouldn't bother IMHO, the return on investment and the benefit doesn't justify the effort.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Very True!!!! The Rear needs diff cal's all together LOL
Posts: 1,423 |
Originally posted by Stazi: Guys to run FSVT's in the rear will need a different bracket again, and frankly I think it would start looking a little ridiculous seeing as the actual swept area on the FSVT rotors, buy a stock rear pad would be patheticly thin compared to the diameter of the rotor.
I realize that a different bracket would be needed and may even take it on myself...I have been thinking about this for quite a while. I'm running 18" wheels and the stock SVT rear rotor looks lost, the 13" Baer looks great up front. But as stated the bias is probably off a good bit with this combination. Just wondering if the FSVT 300mm would be better then the SVT 280mm in the rear in combination with the Baer 13" 330mm front brakes?
If you had the option which would be best? front 330mm (13"), rear 280mm (11") VS. front 330mm (13"), rear 300mm (11 13/16")
Thanks
Scott
2002 F150 SuperCrew
Posts: 10,015 |
Scott - look at what I said. The REAR pad and caliper will look ridiculous (i.e. lost...as you put it) on FSVT front rotors.
AUSSIE ENDLINKS $70
Posts: 759 |
Thank you guys for all the effort and hard work you put into this. I am in need of a brake job, so hopefully all of this can be available in the near future. Chalk me up for FSVT Rotors/Pads, Front and Rear brackets, Rear pads
Posts: 1,423 |
Originally posted by Stazi: Scott - look at what I said. The REAR pad and caliper will look ridiculous (i.e. lost...as you put it) on FSVT front rotors.
ok I got it now I suppose I'll be getting a set of rear brackets when they are available.
too bad this car doesn't have an internal drum e-brake/disk brake set-up...rear upgrades would sure be a lot easier
Thanks,
Scott
Scott
2002 F150 SuperCrew
