Posts: 240 |
Originally posted by svtProdigy: Originally posted by todras: That's why you join them. The 3L section bolts to the 3L LIM. Are you being serious or do you not have any clue of what you are doing?
I don't think you realize what this thread is about...
I no exactly what needs to be done but i need a higher volume rail! Like from the noble or svt. The escape rail just does not cut it. Once i find out what will work then i will braze the two together.
I would have to say the Mazda6 rail is the higher volume rail, seems larger than any other Duratec rail I have seen in person. Though never cutting one open, I can't say for sure and can't tell you what all modifications you need to make it work.
Driving the Caliber
Side project: The LT-5 Fiero is being born..
Posts: 1,190 |
Thanks that is exactly the info I was looking for.
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 10,015 |
What volume of fuel can you possibly be running that needs such a huge rail? You didn't buy those 96# injectors that one clown was saying he was going to install, did you?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,190 |
Originally posted by Stazi: What volume of fuel can you possibly be running that needs such a huge rail? You didn't buy those 96# injectors that one clown was saying he was going to install, did you?
It was 42lb injectors.. Not a huge rail..The escape fuel rail is so thin compared to the svt so i figured i needed one comparible to it.
#702 of 2150
Posts: 9,065 |
Originally posted by svtProdigy: Originally posted by Stazi: What volume of fuel can you possibly be running that needs such a huge rail? You didn't buy those 96# injectors that one clown was saying he was going to install, did you?
No no no...the rail will be fine with the 42# injectors. My question tho is whether or not you know that the returnless rail needs to be modified in order for it to work with your car!
Posts: 1,190 |
Originally posted by Twisted6: Originally posted by svtProdigy: Originally posted by todras: That's why you join them. The 3L section bolts to the 3L LIM. Are you being serious or do you not have any clue of what you are doing?
THis has been covered..I realize it needs to be modified..I just want the best fuel rail for my application to modify. thanks for the concern though.
#702 of 2150
Posts: 611 |
There shouldn't be any issues with the escape rail. It is much easier to modify than the Taurus or Sable rails.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 1,190 |
Originally posted by Blackcoog: There shouldn't be any issues with the escape rail. It is much easier to modify than the Taurus or Sable rails.
this is notthe issue here. I know its easier and what i have will bolt down. My concern is this:Re: fuel rail From: DemonSVT As long as the rail is not smaller diameter then the incoming fuel line you will not have a lower power potential.
i beleive its smaller.
#702 of 2150
Posts: 1,210 |
The escape rail is much bigger than the SVT rail just to let you know
As i said before the first pic you posted is the ESCAPE fuel rail...
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 611 |
The over all inner diameter is larger on the escape rail but I think the wall thickness is slightly smaller. I'm not sure what your more concerned with. Either will work with 42lb injectors as other's have shown.
